Question about Thermador HGSI42TS Kitchen Hood
Thermador downdraft will not retract - Thermador HGSI42TS Kitchen Hood
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
Posted on Jan 17, 2011
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My thermador stove fan keeps going up and down cvs45r
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
Downdraft doesn't alway go down and up.
I have the same problem. Seems to be pretty common that the motor that raises the unit goes bad. Ours is 2 1/2 years old and has not seen that much use....that motor should not have failed that soon...and this is a high end product!!! I have been quoted $289 for a replacement motor and $150 for labor!! So, $450 bucks....gads. The unit, new, cost about $900, as I recall.
May 08, 2007 | Thermador UCV36ASS Kitchen Hood
Thermador HGSI42TS Kitchen Hood Logo
74 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
