Question about Precor Exercise & Fitness
Circuit breaker Hi have A precor 932i have no power outlet has power checked circuit breaker with ohm meter keep getting a - number cord looks good
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: i am working on Precor 932i treadmill, not having any luck yet. I have found a load resistor ,100 ohm 50 watts burnt out. would this cause the treadmill not to power up?
Dear Sir:I am recommend you to exchange the board. If you do not have ENOUGH experience will be better to buy a new one, or call some tech profesional for to execute this delicate work.
The causes can be various, Maybe you have SHORT circuit in the motors, power supply, see the block diagram.
God bless you
Posted on Sep 20, 2012
  • 6 Answers
SOURCE: What would cause the Ift Drive Module 110 v fan not to work on a 932i treadmill?
http://r.ebay.com/zK31KK check out this link..might be a interested to u..if interested call 3477376296
Posted on Sep 29, 2012
Skill saw table saw model 3400.Bypassed on off switch still no power?Does motor have a breaker on inside?
I have the same saw.
Sorry but this question has to be asked, is the AC (Alternating Current) outlet working/ an live outlet? Had to ask.
If outlet is good move on to the next steps.
Take an ohm meter / continuity meter.
With the AC power cord unplugged from the AC wall outlet.
Place the two test leads from the meter onto the plug prongs .
With the switched closed/ON, you should get zero ohms (or very low, close to zero/ continuity).
In your case you probably will not have any continuity because it doesn't turn on.
Now comes the fun part trying to find the problem/ open connection.
Lots of possibilities.
  1. The AC cord could be bad at the plug end.
  2. The AC cord could be bad at the point entering the table saw.
  3. The motor could be bad.
  4. The brushes in the motor could be bad.
  5. The field winding in the motor could be open/bad.
The plan is to ohm/continuity check the path of the power going to the motor, (both sides of wiring).
While meter leads are on the AC plug end, wiggle the strain relief ends. You have an intermittent connection.
TROUBLE: SAW WILL NOT START
PROBLEM 1. Power cord is not plugged in.
2. Fuse or circuit breaker tripped.
3. Cord damaged.
4. Burned out switch.
REMEDY 1. Plug saw in.
2. Replace fuse or reset tripped circuit breaker.
3. Have cord replaced by an Authorized Skil Service Center or Service Station.
4. Have switch replaced by an Authorized Skil Service Center or Service Station.
May 25, 2016 | Saws
The speed on my Precor 932i won't adjust any faster than 1
HI There,
Did you get this worked out? Possibly the IFT drive?
Sep 08, 2015 | Precor 932i Treadmill
Washing machine stopped no electrical power at machine
Did you check the circuit breaker? Testtheoutlet with a voltage meter.
Dec 11, 2014 | Washing Machines
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
Sep 28, 2012 | Exercise & Fitness
I am working on Precor 932i treadmill, not having any luck yet. I have found a load resistor ,100 ohm 50 watts burnt out. would this cause the treadmill not to power up?
God bless you
Sep 19, 2012 | Precor 932i Treadmill
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
It has an error 15 that keeps poping up
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
Mar 02, 2011 | Precor C956 Treadmill with Cardio Theater...
Hi I have wired my house and would like to confirm all the connections before applying power. It looks like this unit is just the trick. Will it work if there is no electrical service to the building yet?...
No it needs to have power to work....you plug the one unit into a powered outlet and then you can "find" the breaher in the panel with that unit...
For what you want to do you need an "Ohm meter" which integrated into many electrical meters.
heatman101
heatman101
Aug 20, 2010 | Gb Electrical CS550A Circuit Breaker...
I'm trying to connect a GSW-SK door switch to an led rope light. The circuit breaker trips every time I plug the power cord into the outlet. Any ideas?
The circuit breaker trips because you have some sort of short circuit. Use a Meter set to OHMS, and try to find the "Short". Check the wiring in the Plug also.
Feb 11, 2010 | Gardner Bender #GSW-SK Door Switch
Exercise & Fitness Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
