JUST ONE OF COUNTLESS SWORDS SITTING AT THE READY ON PEDESTALS OF BEAUTY
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
What's a Katana sword?
Many warriors believe that each Katana sword has its own soul those with a great history in particular. To lose this sword is a dishonor and the warrior which loosed the sword is considered to be an irresponsible man. This sword is almost never used in battle and using it is considered to be a dishonor on the sword's soul.
Aug 05, 2012 | Martial Arts
Separating a glass tv pedestal from a glass tv cabinet
I can only figure that the cabinet is Not part of the TV's normal design and it has been just sitting on this cabinet for a long while?
If this is so then it has by weight and heat sweated itself onto the top, synthetic feet are made of complex materials including oils which get exuded then form a quite powerful glue action, also that spray polish has baulking agents to make it look good in use these act as glue.
If this top is glass then its pretty well resistent to most things, try windolene glass spray its safe and dissolves many things on glass as a cleaner (or other surfaces). Move up to say WD40 a mineral oil again safe wipe clean with meths spirit to clean up just add in a bit of tilting to break that grip.
Hope this helps......
Jun 27, 2017 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
I have a 98 dakota sport 3.9 and it has been stalling out and not wanting to start back up i have replaced the crank sensor, coil , pick up coil, cap and rotor button and its still happens ohh after it...
i have the same issue, im about ready to get a can of gas, douse it all over the outside of the truck and let it burn! im so sick of this!countless hours of trouble shooting, and hundreds of dollars on parts to trail and error!!!
Feb 24, 2011 | 1998 Dodge Dakota
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
2)Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3)Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4)Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Can't access Temple of Time
Are you using the master sword? I know it's silly to ask that but it's the only non glitch related answer that exsists
Mar 05, 2009 | Nintendo The Legend of Zelda®: Twilight...
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
177 people viewed this question
jasbo
jasbo
