Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
I have a Medline Srider scooter and when I turn the key on the green light blinks seven times pauses and blinks seven times again
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
Repair pride dart mobility scooter when turn on green light blink on won't moved
The blinking light is a fault code. The light will blink a series of blinks and then pause. To better answer your question you will need to know the fault code the scooter is giving
Oct 26, 2013 | Universal D5722alt9-compatible Wheelchair...
Rascal liteway 224 scooter
Hi Allen,
The problem is that although it is physically in neutral, the safety switch for indicating it is in neutral is not working correctly. It could be the switch itself or the wire(s) from the switch. Get a manual and see if you can trace the wires from the neutral switch.
Aug 06, 2012 | Health & Beauty
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
Kenmore DW blinking clean light 7 times, pausing, blinking 7
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Oct 11, 2009 | Dishwashers
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
