When turning monitor stays in the "E" for at least 10 -15 min.
I had moved my computer to another room and had unplugged all connections to do so. After reconnecting everything, everytime the computer is turned on it displays the Bios & Boot Menu screen. The monitor also tells me to check settings. It stays in this mode for about 10 - 15 minutes.
    Problem Solver:
  • 5 Answers
Are you using an onboard vid card or addon? If so be sure you are plugging it into the same spot, also if your bios did a reset(can happen with an old cmos battery) then it may default to the onboard video which you would have to change in the bios settings.
Posted on Jun 22, 2009
  • 11,896 Answers
You can do a system restore which will set the computer back to previous settings. If it is not allowing you access at all, It may be loose video card.
Are you able to access your control panel?
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
I lost the color blue. Is that a monitor problem, driver problem, or some kind of graphics software problem? And, how do I fix it? This occurred after I unplugged and moved the computer into another...
It may just be the cable, or the connector that attaches to the monitor or pc.
This monitor also had a similar problem, it was connected with a dvi to vga adaptor on another computer. I plugged it straight into the vga socket on this computer and it works fine.
If that is no help, you may need a new monitor
Aug 03, 2010 | HP w2207 Monitor
Benq t903
Hello
Possible bad Monitor video cable.Or video device is bad.
Try unpluging the pc completly from the wall for 5 min then plug back in and restart.
Also check that connections are solid and tight on monitor video cable.
Apr 29, 2010 | BenQ T903 19" LCD Monitor
Dell Computer Monitor - Black Screen
If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
Please vote if this helps.
nLinked
Computer Support Services
Jun 08, 2009 | Dell E193FP 19" LCD Monitor
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
I moved my computer to another room and now the monitor won't work. When I turn the computer on, the light turns green on the monitor for about 2 seconds then goes to orange and the screen stays black. If...
Make sure you don't have two video cards on your machine and have plugged into the wrong one.
Failing that, open the case and make sure the card is plugged firmly in its slot (do this with the power off).
Sep 29, 2008 | Computers & Internet
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Computers & Internet Logo
Alun Cox
David Payne
David Payne
