Question about Home
Proport scales 3175
Battery replaced will not work, displays --- only
3 Suggested Answers
SOURCE: My bathroom scales ww35cha stopped working, i
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Posted on Jan 22, 2010
budmrtn
  • 11361 Answers
SOURCE: The X-Y proportions on the display are not right.
Native resolution for this monoitor is 1024 × 768 @ 60Hz (native and maximum). for correct ratio.
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Posted on Aug 31, 2010
Just replaced battery in my Conair WW87 scale and the numbers now do not display fully. Broken up
Recheck the battery connections and check the batteries, this type of display most times means low battery voltage.
Sep 12, 2016 | Conair Weight Watchers WW-87 Body Fat...
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Dec 29, 2008 | Taylor Dgtl Body Fat Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Home Logo
67 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
