Question about Husqvarna Garden
Model YTH22V46 - backfires when I shut it off
My Husqvarna yth22v46 model 960430101 has black smoke coming from exhaust and is running bad, what is wrong?
The engine is running rich, you need to overhaul the carburetor. Take it off and take all the parts off of it and out of it and soak it in cleaner and replace all the o-rings seats and gaskets OR buy a new carb.
Jul 28, 2017 | Cars & Trucks
Husqvarna tractor Model YTH22V46. Transmission rod engaged, foot brake depressed, engine running, when you let the brake pedal out the engine quits immediately! What is the problems?
It sounds like you have a safety switch bad. Check the seat switch first and then the brake switch. This should correct the issue.
Feb 12, 2017 | Husqvarna Garden
How do I remove the plug in top of hydro transmission, does it screw in or just plug in?
In most cases the plug is pressed into the transmission. Many times during the removal of the plug it will be damaged. Also, use care not to allow debris into the transmission, this will damage the transmission.
May 09, 2016 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
How do i cahnge the oil
There a plug on right side of motor.Screw it out and turn off oil filter
Sep 06, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
Mowing lower on right side than the left
Loosen the adjuster on one side of the deck and level off the deck and retighten. This should be done on top of a solid surface so u get it perfectly parallel to the ground.
Aug 30, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
Husqvarna YTH22V46 install clutch cable
Do you mean the electrical cable which feeds the clutch?
Jun 24, 2014 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Reverse operating system
Check the switch down by the gear shift lever, and the wiring to the switch, if one of the wires has come off the switch it will give problems.
May 30, 2013 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
BACKFIRES WHEN YOU KILL IT.
Let it idle for 5 minutes before shutting the engine off to stabilize the internal temperature, that should stop the backfiring which is fuel lighting off when hitting the hot combustion chamber surfaces.
May 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Galant 95 backfires and shuts down at higher rpms
check ur plug wires they might be mismatched ...joe
Aug 29, 2009 | 1995 Mitsubishi Galant
Garden Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
