Question about Samsung DW80F800UWS 24" Stainless Steel Built-In Dishwasher 15 Place Settings, Energy Star
Why is my Samsung DW80F800UWS leaking right side
Tip
Fixing 5E or SE error code on Samsung model Dishwasher
Our 13 month and very expensive Samsung dishwasher model DW80F800UWS stopped working and displayed error code 5E or SE if you don\'t know they all start with a number (which I did not). After 2 weeks of pain with "repair man" an fixed it myself and I wanted to share my success story.
This dishwasher uses an optical sensor to detect how much water is in the tub body. Older dishwashers use a simple float but Samsung had issues with these sticking open so they must have switched to the solid state sensor at some point. Believe it or not if the sensor gets dirty with gunk from food the sensor false reads that there is still water in the tub and shuts down with error code 5E. The sensor is removed from the right side access panel (when looking at the machine from the front. Its a small round clear plastic sensor held in with black plastic clip. Take it out and clean off the gunk. Re-install and wham bam thank you mam!! Your wife will think your a genius!! total cost of repair is Zero...yes that right ZERO!
Part number for this sensor is DD32-00003A and you can use the Sears website to see the diagram and location. Here is the link
http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dishwasher-Parts/Model-DW80F800UWSAA0000/1482/0130000/Q0042928/00006?blt=06&prst=&shdMod=
I wish I would have done my homework first as I had a failed service call before I fixed it myself! Cost me some money I hope others can avoid!
on Jan 10, 2015 | Samsung Dishwashers
I have an SE error message. Past warranty.
See if thhe error message is listed in the trouble shooting section of the owners manual.
May 15, 2016 | Samsung DW80F800UWS 24" Stainless Steel...
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
Se code Samsung DW80F800UWS What should I look For?
Theres a 5E I can't find a Se
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Nov 22, 2014 | Samsung 24 " Built-In Top Control...
DW80F800UWS water level sensor
That's the case-brake assembly, located on the left-hand side of your dishwasher.
Aug 29, 2014 | Samsung 24 " Built-In Top Control...
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
Water in the bottom of the frig, right side.
Find the condensate drain in the bottom of the frig and clear it
Jun 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung DW80F800UWS 24" Stainless Steel Built-In Dishwasher 15 Place Settings, Energy Star Logo
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
