Question about Xerox Office Equipment & Supplies
Recently replaced fuser unite in Xerox C3290FS Docuprint but it needs to be reset
SOURCE: Xerox Docuprint C1618 Colour Laser
it resets with a new drum, there is a chip on the drum ( CRUMB) that resets the main PCB count when you install a new print unit.
Posted on Oct 08, 2008
  • 2072 Answers
SOURCE: how do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Nov 26, 2008
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
nakshatraipu
  • 241 Answers
SOURCE: How to reset the Xerox DocuPrint 32100 Chip
we have reset software for xerox 3210 printer. www.nakshatraworld.com
Posted on May 28, 2010
  • 239 Answers
SOURCE: Need to replace the fuser unit kit in a xerox m20 copy machine
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Posted on Aug 23, 2010
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Ive got a xerox docuprint C3290FS that keeps comong up with this scanner sensor error 062-360, is there any way to fix it besides replacing the upper section of the machine? Thnaks.
Ive got a xerox docuprint c3290fs and everytime we fax it comes up with error 035-701 and it takes a couple of goes then it eventually goes through is there any way we can fix this problem?
Oct 13, 2010 | Xerox DocuPrint C3290 Printer
Fuji xerox docuprint c3055dx printe
please check the pick up roller on the unit. maybe it is worn out. if so, please replace it.
Mar 05, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
Dec 10, 2008 | Xerox DocuPrint 3210DX Laser Printer
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
Fuji xerox docuprint c1618 error
001-360 Fan motor failure Check Fan Rear Check Fuser Fan Check voltage on fan rear should be between 15VDC and 24VDC. Check voltage on fuser fan should be 24VDC
Dec 29, 2007 | Office Equipment & Supplies
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
