Question about Xerox Office Equipment & Supplies
Xerox C3290FS fuser unit reset
  • 2072 Answers
SOURCE: how do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Nov 26, 2008
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
Posted on Jan 13, 2010
  • 2072 Answers
SOURCE: xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Posted on Jan 28, 2010
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
  • 239 Answers
SOURCE: Need to replace the fuser unit kit in a xerox m20 copy machine
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Posted on Aug 23, 2010
Reset phaser 3100mfp xerox fuser
Hi Anonymous,
What exactly did you mean, did you want to reset the printer or the fuser?
I would suggests www.xerox.com or the Xerox concessionaire would be the best place to start.
Regards.
Aug 25, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
How to reset Phaser 6110 imaging unit.
No reset for imaging unit, only when you change it(autoreset).
You can reset Fuser and Transfer Roller this way:
To reset the fuser and transfer roller life usage from the printers control panel:
a. From the main menu select, Menu-Setup --> Maintenance --> Check other.
b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons
c. Select Reset.
May 18, 2011 | Xerox Phaser 6110 Laser Printer
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Ive got a xerox docuprint C3290FS that keeps comong up with this scanner sensor error 062-360, is there any way to fix it besides replacing the upper section of the machine? Thnaks.
Ive got a xerox docuprint c3290fs and everytime we fax it comes up with error 035-701 and it takes a couple of goes then it eventually goes through is there any way we can fix this problem?
Oct 13, 2010 | Xerox DocuPrint C3290 Printer
Xerox 6250 will not warm up. it says
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
I have blocked the fuser uit
May 20, 2009 | Xerox Phaser 7760/YDX Laser Printer
My Xerox B/W Copier XC 1044
When was the fuser last replaced?
Jun 09, 2008 | Office Equipment & Supplies
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
10 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
