Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Cub cadet l60 battery won't stay charged - Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
3 Suggested Answers
  • 218 Answers
SOURCE: Cub Cadet 1042 won't maintain a charge-
Hi...my name is Keith..and there is a couple of things that could be a problem...(1) is the battery cables needs cleaning or...(2) the ground connection to the frame is rusted or...(3) the engine alternator is bad.or needs attention...or (4) you have a bad amp meter(if one is installed on your mower)..i hope this has helped..if not..please write back
Posted on Jul 04, 2009
SOURCE: the electric clutch on my cub cadet lt1045 does not stay running
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Posted on Jun 14, 2010
Cub cadet lt1050
Is the red light on before you engage the blade?
There may be a blown diode in the charging circuit.
Battery- If this light illuminates while the engine is
running, it indicates that the battery is in
need of a charge OR that the engine's
charging system is not generating sufficient
amperage. Refer to Battery on page 26 of
this manual for the properbattery charging
procedure or have theengine's charging
system checked by a Cub Cadet dealer.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Aug 27, 2014 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
Battery will not charge on cub cadet 1515
is it not charging or is the battery bad and can't be charged anymore there only good for a few year
Aug 28, 2012 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Our cub cadet will run and mow for a short time then it shuts down and won't start if we let it set for awhile then it starts it done this about 4 times now it acts as if it needs the battery char
Take your battery to Oreilly's or autozone,, ask them to check the CCA (Cold Cranking Amps).. this is the true measure of battery quality... if its low, they will tell you and get a new one... see if it runs better,,, it not... you may need the assistance of a qualified professional.. ( may be a coil)..
Aug 10, 2017 | Cub Cadet Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
35 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
