Question about Miele 30 in. KM443 Electric Cooktop
How do I unlock two of the four burners on my KM443 ceran cooktop?
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    My right front burner only has heat on the inner circle. what do i do.
    It could be the switch. I have a handy video that shows what to check: HERE
    Jan 14, 2010 | Miele 30 in. KM443 Electric Cooktop
    Should I buy a two burner unit if available? Or a new cooktop?
    Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
    Dec 29, 2009 | Cooktops
    Hello I have a Miele Deluxe H818 oven With a Ceran Schott cooktop I would like to buy a used or new cooktop The size is 23 1/2'' by 20 3/4 the reason I would like to replace it is the top is marked and 2...
    Hallo I have a Miele Deluxe H818 oven too.
    I do not use my cooktop because I buy new with gas-metan.The original cooktop is only electrical.
    Ivo
    Nov 09, 2009 | Cooktops
    Ceran stove top will not unlock.
    Unlock Kitchenaide Caren stove top
    Oct 13, 2009 | KitchenAid Cooktops
    Can't turn it "ON"
    seeming like you forget how to lock off.
    keep the lock icon pressed stronger and longer,until will hear a beep,then turn it on
    Aug 03, 2008 | Miele 30 in. KM443 Electric Cooktop
    Ceran stock top chipped and cracked
    most of thoose ceran tops have a five year parts only warrenty read your owners under 2-5 years warrenty if it does call ge cust assistance to see what you can do
    Jan 20, 2008 | GE 30 in. JGP328 Gas Cooktop
    Miele 30 in. KM443 Electric Cooktop Logo
    97 people viewed this question
    Top Miele Cooktops Experts
    mpservices
    Are you a Miele Cooktop Expert? Answer questions, earn points and help others
