Question about Ford Vehicle Parts & Accessories
How do i change a timing chain on a Mazda mpv 2000
    Genius:
  • Ford Master
  • 2,494 Answers
Check if it has a chain or a belt drive.
Posted on Aug 02, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
When do I replace the timing belt
hi.
a 2000 mpv should be the newer model (older model stopped 1998)
all newer models were fitted with a timing CHAIN which does not need routine replacement.
Mar 02, 2011 | 2000 Mazda MPV
Does a timing chain need to be replaced on a 2000 Mazda MPV with 112,000 miles. No problems just curious.
timing chains let you know when its time to change them as they rattle but if you do a rebuild at say 200k then obviously change the chain/tensioner
Jan 31, 2011 | 2000 Mazda MPV
Timing set cams to crank?
complex job chains have coloured links to line up with gears and a set number of links between timing marks, best get a manual or a professional to do job
Apr 24, 2010 | 2000 Mazda MPV
Does the 2000 mpv model have a cambelt?? this is an automatic
Timing chain, and usually will not require sevice. Check owners manual service reccomendations
Feb 04, 2010 | 2000 Mazda MPV
Where do i find the water pump and how much to replace.
INFO:
Water pump runs off of the timing belt.
ANSWER TO QUESTION:
Water pump can be replaced for about $300.00
RECOMENDATION:
Use only factory original belt.
Hope this tip helps.\
R/
David
Jan 31, 2010 | 2000 Mazda MPV
Cost for timing belt/ chain on 2000 mazda van ?
if a mechanic does it about 300 dollars parts and labor
Jan 17, 2009 | 2000 Mazda MPV
Drive Belt
How does the belt look, and when was it last changed? If it's the original or shows signs of splits or cracks, yes, change it, preventative maintenance is much better than having it break and getting stranded somewhere, and maybe even overheating the engine. countrycurt0
Sep 09, 2008 | 2000 Mazda MPV
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
