Question about Xerox DocuPrint C3290 Printer
Reset fuser unit - Xerox DocuPrint C3290 Printer
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
Hello, I replaced the fuser on my 734de and I still get fuser life warning
Did you replace the fuser with a new Lexmark fuser or a refurbished unit? The original Lexmark units have a chip in them that resets the counter when installed. However this only works the first time the fuser is installed. If you install a used fuser in a different printer it will not reset the counter.
Sep 30, 2014 | Lexmark Office Equipment & Supplies
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
C300 Fuser unit reset
To reset fuser unit you need change the 60mA/250V fuse,located in the fuser unit contact house (a little green diode).
Dec 24, 2013 | Konica Minolta Bizhub C300 All-In-One...
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Jan 05, 2009 | Brother MFC-8460N All-In-One Printer
Xerox DocuPrint C3290 Printer Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
