Question about Brother P-Touch PT-D200 Label Printer
Won't turn on
I have it plugged in to the ac adapter and it won't turn on
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
Aug 09, 2012 | Dell Inspiron 1545 Black Intel Celeron 900...
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Won't turn on
I had the same problem. I discovered that there's a light on the AC Adapter (under the back cover). The light on mine wasn't coming on when I plugged it into the wall. I used an AC adapter from another frame and the PAN1502W02 turned on immediately. Off to Radio Shack to see if I can purchase a replacement AC Adapter.
Aug 13, 2011 | PANDIGITAL 15-inch Digital Picture Frame...
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My HP Mini Netbook will not turn on and the battery will not charge.
Perhaps your AC Adapter is bad. That is the cable that plugs into the wall and then into your laptop to charge it. Take the laptop into your local computer repair shop to see if they have a used replacement, or a Universal Laptop charger. We sell them at my store. www.ravencomputers.com. If you can't find one, go to our website and either email us or call us and let us know, we can ship anywhere in the US. If you try another AC Adapter and it still won't charge, then most likely your battery is bad. You can also try pulling the battery out and trying to turn it on with just the AC Adapter plugged in. If that works, then you know the battery is bad.
Jun 21, 2011 | Computers & Internet
Printer won't turn on and AC Power Adapter plug is making a humming noise.
hi
if the AC adapter is humming, refrain (stop) from using it !
the adapter is physically damaged and the internal transformer has been dropped several times to make such a noise.
you will have to purchase a new AC adapter, p/n should be and it should cost about $10-$15
ADP-25FB
pleae issue 4 thumbs up ... thanks for using FIXYA
May 10, 2011 | Lexmark X5150 All-In-One InkJet Printer
Brother P-Touch PT-D200 Label Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
