Question about Hayward Pool Products Hayward Northstar 1HP Up Rated Pump
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot. Checked the electrical box, all is good. The pump is only 2 years old. Any suggestions?
    Sergeant:
    Champion:
  • 324 Answers
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
Posted on Nov 07, 2014
4 Suggested Answers
  • 59 Answers
SOURCE: Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Posted on May 25, 2009
  • 77 Answers
SOURCE: I have a hayward pool pump. I ran the back wash
It sounds like the start switch contacts are not making good contact or there also may be a weak capacitor. These possible solutions do require a basic knowledge of motors to remedy. Start contacts can be cleaned and adjusted until proper replacement can be done.
Posted on Aug 18, 2009
Testimonial: "Thanks for the help. It worked."
  • 8404 Answers
SOURCE: My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
What else could cause power to pool pump to shut off?
Check the timer clock, the timer maybe faulty or the time is incorrect.
Oct 13, 2012 | Hayward 1HP Super Pump II Inground Pool...
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
I have a clicking noise coming from the new Hayward super pump.
Is the motor running? It will make an audible 'click' when it turns on and another as it slows to a stop once shut off. If it keeps doing it during the run time, you are likely not feeding it the correct voltage. Otherwise, one click at the start and end is normal.
If the motor is set for the correct voltage and the line voltage is ok, the motor is starting to fail and will need service at a local electric motor repair shop.
Jul 12, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
2 yr old inground pool Hayward pump louder than normal. Bearings were checked and seals replaced prior to opening this summer.
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Jul 10, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward 1 hp super Pump just hums then shuts off.This is an inground pool
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward Pool Products Hayward Northstar 1HP Up Rated Pump Logo
83 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
