Question about Juki TL-98Q
Juki tl98q will not run. The machine powers up, it will cut thread,but the hand button will not turn the machine on to stitch. Both the machine and the hand button are new.
  • 4 Answers
Is your bobbin threader pulled over? If it is the machine thinks your trying to fill a bobbin.
Posted on Aug 21, 2009
First check your "fill bobbin" lever on top: make sure it's open all the way. (Try opening and closing it several times.) If this is even slightly in the closed position, the feed nor the needle assy will not move.
Next, make sure your foot pedal is not depressed...tap it several times up-down. If the pedal is even slightly depressed, the feed nor the needle assy will not move.
Posted on Dec 15, 2010
Sewing machine won't run.
1. Make sure the machine isn't set for bobbin rewind. Also, try to move the control hookup around slightly to ensure it is making a good connection.
2. Is it possible the power switch looks like it is on but isn't because of the surrounding light? Check this and the outlet you are using.
3. Is the sewing machine light on? A puppy biting in the wire could have caused a short so a pro will have to check the guts of the machine.
Aug 08, 2016 | Juki TL-98Q
Juki owners manua for Tl 98q
Learn how by downloading the Users Guide from the link below.
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Hope this helps.Thanks!
Ken.
Jan 11, 2012 | Sewing Machines
I have a juki tl98q sewing machine for my mid arm. The bottom thread keeps bunching up and I cannot sew anymore. What can I do to fix this? Do you have a diagram to thread the bottom bobbin and the top of...
The threading diagrams are available in the manual which is available from Juki on the TL-98Q product page: http://www.juki.co.jp/household_en/pism/tl98q.html . The direct link to the manual is http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf . See pages 14-18 (pages 16-21 of the PDF).
There are a couple of things I recommend that you check. First, make sure that the bobbin is evenly wound. This is a function of the bobbin winder tension; see the manual (page 15) for that adjustment. Next, check if the bobbin case tension is correct. Place the bobbin in the bobbin case and dangle the unit from the thread. Try to shake the bobbin case up and down, sort of like a yo-yo. The thread should advance by a bit. If the thread length doesn't change, loosen the set screw on the side of the bobbin case a small amount. If you get a really long tail of thread, tighten the set screw. See page 21 of the manual.
Next check for any loose threads and dirt in the housing around the bobbin case. Depending on the length of time that you have been using the needle, replace the needle.
I hope this helps.
Sep 28, 2017 | Juki TL-98Q
Juki TL98Q long arm quilting machine: can sew perfectly then all of a sudden a series stitiches are skipped. Why?
Using a long carpenter's level, level up your frame. Low areas in the frame can cause skipped stitches. Also, check the wheel sensor wheels-are they making good connection? These can lose connection when you quilt in certain directions.
Feb 13, 2011 | Juki TL-98Q
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
Jul 29, 2010 | Juki TL-98Q
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
My juki tl98q foot pedal and thread cutter has stopped working. help
Check the power cord and then take apart the side door and check the thread cutter for any displaced working machanisms. OK!!
Nov 28, 2009 | Juki TL-98Q
Juki TL98Q needle thread breakage
your bobbin it is not in his right position, quit tightin your tension.
Sep 29, 2009 | Juki TL-98Q
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Juki TL-98Q Logo
282 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
