Question about Garden
Garden hose repair - Garden
2 Suggested Answers
dnsnakdndjws
  • 708 Answers
SOURCE: I see hose repair parts in house and garden stores. How exactly do they work?
do not worry,i goe a garden hose double latex core solid brass connector ,and he use of solid brass fittings makes the hose free from leaks and cracks that often come with plastic fittings. Built-in shut-off brass valve saves you endless trips to the faucet Amazon com MALLCROWN Expanding Hose Strongest Expandable Garden Hose...
Posted on Nov 26, 2016
High pressure water sprayer hose repair
no repair as it is a high pressure hose
a new one is the fix
Feb 22, 2017 | Water Garden
2004 grand prix is leaking coolant as fast as i put the garden hose in it
sadly no one here can help you ,go see a mechanic .you may have a soft plug rusted thru or a cracked block
Sep 26, 2016 | 2004 Pontiac Grand Prix
Can you fix broken hose connection without buying whole hose?
are you talking garden hose or what?
if a garden hose ,just cut the end off and get fittings from your local hardware shop
Nov 22, 2015 | Cars & Trucks
Hi Colleen:
Easy as 1-2-3
1- Cut off the bad fitting
2- Slip the clamp over the hose and push the replacement fitting into the hose
3- Align the clamp and tighten it.
Back to the garden!
May 21, 2015 | Garden
What are garden hoses made from? is it just rubber?
The common hose is made from a synthetic rubber, but some newer hoses are made from soft plastic. the only other important material is a web of fibers on the inside of the hose, that you can only see if the hose gets a rip or if you cut it
Feb 17, 2013 | Garden
I have a Miele dishwasher that has a small leak by the intake hose which is connected to the water supply. How can this part be repaired or must it be replaced
The inlet hose to a miele dishwasher has a box on the end of it, and a brass garden hose thread fitting on the end of it. Inside this brass fitting is a black rubber garden hose washer. I have never seen the hose break. Are you sure it is not leaking from the washer or maybe missing the washer altogether? It is expensive to get the hose replaced.. 200+ for the hose and 175 for the service call. the dishwasher has to come out and be turned on its side to replace it.
Nov 21, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
Where do I find garden hose attachment
You can find garden hose attachments at a lot of different places. Your local hardware store ought to have a variety of attachments to choose from. Many stores like lowes and home depot carry things like this in the garden center. When to Plant Garden
Jun 07, 2009 | McCulloch FH180A Electric Pressure Washer
I'AM LOOKING FOR A DIAGRAM OF THE COOLING SYSTEM; SO I CAN DISCONNECT THE HEATER HOSE AND USE A WATER HOSE TO RUN THROUGH IT TO SEE IF ANY DEBRIS ARE TRAPPED BLOCKING WATER FLOW
This is how I flush the heater core...go to the garden department at Wal-Mart and get a 5/8 - 3/4" female garden hose connector similar to my picture...remove the upper heater core hose and connect your garden hose to the connector then to the heater hose and secure with a hose clamp. Remove the lower heaer core hose and point it to the gound, then turn on your faucet and run clean water thru it... b67bfc8.jpg
Mar 24, 2009 | 2001 Chevrolet Venture
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
