Question about Cycling
110Cc atv getting gas and fire but wont start
SOURCE: no spark
check for the wiring...we used to bought some of those atv hummer style...and there is no continuity in the wiring because of bad terminal connexion to the inside brush of the cable...or you have a faulty stator....coil and cdi is not the main problem on those cheap engine....loncin,bears,zongshen....
Posted on Sep 21, 2009
  • 9 Answers
SOURCE: i have a 110cc chinesse built atv. i got gas in
These engines are based on the awesome Honda design. Unfortunately, they do not have the same quality. If you verify there is fuel getting to the cylinder and there is also spark, you need to verify compression. One of the tendencies of these engines is the valves will actually tighten as they wear in. This can cause the valves to open prematurely which causes all kinds of starting issues. Check you compression and run a leak-down check to see what the compression portion of your engine looks like.
If you need to adjust your valves, do this with the engine cold and spark plug out.
  • Remove the valve caps (I believe these are 17mm and they are located on top and bottom of the cylinder head.) There may be a little oil come out of the lower (exhaust) cap.
  • Remove the left side cover. This is left side if you are riding the bike. This is the stator side and there should be no oil in this part of the engine. This will also allow you to turn the engine and align the piston with top dead center.
  • Rotate the engine counter clockwise until the alignment marks, sometimes indicated by a "T" are aligned with the mark on the case. If both valves are closed, you should be at top dead center. If they are not, make one more rotation.
  • Use a feeler guage to check clearance between top of valve and rocker arm.
  • I believe you will need to use a 10mm wrench to loosen the adjuster lock on the rocker arm. Once loosened, the adjuster will screw up or down as needed.
  • If needed, adjust the intake valve to:.05-.09mm and the exhaust valve to: .11-.15mm.
  • Once adjusted reverse the process.
If your valves are good to go and you are still having this problem. Remove the flywheel and verify the alignment key has not sheared on the crankshaft. The ignition timing on these Chinese engines is not adjustable, but can be off significantly if this key is sheared. I hope this is somewhat helpful.
Posted on Nov 09, 2009
  • 4 Answers
SOURCE: I cant get my 110cc atv to fire
1. See if you can get a spark.
2. See if fuel does reach carburetor.
3. Is your magneto still good?
4. Is your starter trying to crank up engine?
5. Is your CDI box sound?
So many questions that need to be narrowed down. What have you tried?
Posted on Dec 08, 2009
  • 6 Answers
SOURCE: how to set timing on a china 110cc atv
whats the point? Go buy and American Made bike then I'll tell ya
Posted on Aug 21, 2010
  • 134 Answers
SOURCE: Roketa ATV-32 110cc Chinese ATV
Not that I have been able to find. The Chinese seem to be lacking in the information departments.
Posted on Oct 30, 2010
Marshin atv
make sure all connections are good, and making contact. then ck. the cdi unit is grounded properly.
Jun 20, 2013 | Yamaha Motorcycles
Hello, everybody! I have brought my 110cc Chinese atv to the shop many times and am sick of paying for this reason, I would love it if y'all who know how to fix atv's or motors help me with this probl
please 1. check fuses 2.check spark using a timing light then 3. fuel with a fuel pressure gauge if no spark replace ignition module; if no gas replace fuel pump
Feb 18, 2013 | ATVs
Ares 110cc four wheeler won't start gas not getting to carb
chk your tank and lines for trash blockage, when you get fuel to the carb go from there, the overflowing is caused by the needle valve in the carb sticking open, usually caused by trash in the fuel, make sure you are getting fire to the plug as well, I know for a fact the wiring systems on these things are not quality systems.
Oct 25, 2012 | RTO 110cc Basic Manual ATV # ATD-125C
ATV 110cc idling too fast, giving no gas, it will go like you are giving it gas
check the idle screww and back it out a little bit. if this doesn't change anything then check the air/fuel mixture screw to the right of the carb. counter-clockwise will rev it up and clockwise will lower the rpm's
Jun 07, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
Sep 27, 2009 | RTO 110cc Basic Manual ATV # ATD-125C
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
