Question about Dremel Drills
My Dremel MultiPro 395 is 110, and accidentally plug to 220 volt for few seconds and now is not working anymore, anything can do with this?
freetek
  • 5568 Answers
SOURCE: plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Posted on Aug 23, 2009
radar001
  • 1051 Answers
SOURCE: my drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Posted on Apr 16, 2010
HansPP
  • 2510 Answers
SOURCE: I plugged my dremel 395
It is with regret that I must inform you that you will probably have to replace the whole unit, the field coils will have blown and almost certainly the armature - your did give it a 100% over voltage shock. The prices of the parts will be more than the cost of a new machine.
Posted on Mar 29, 2011
  • 5089 Answers
SOURCE: i plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Posted on Oct 31, 2012
SOURCE: I have a Crosley CR66-PA. It's 120 volts and I
Same thing just happened to a friend of mine, he brought it to me. The transformer primary is Open Circuit, so hopefully that's all that has failed and it didn't do damage to the electronics. The problem I have now is finding out the ratings of the transformer so I can replace it with a 240V one (I'm in Austalia). The markings on the transformer don't come up with anything in google. Any idea what secondary voltage / VA rating it is?
Posted on Nov 17, 2012
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
It is 110 volt accidentally put it in 220 volt line now not working anymore
You will have to plug it into a wall plug with a red button and a black one. And then press the black then red.
May 26, 2012 | Vtech 5.8GHz Analog Cordless Phone
My Dremel sijmply stopped working suddenly. Where do I begin? Brushes?
If you have a volt/ohms meter It is a process of elimination. First unplug tool and remove the brushes turn the switch on and check for continuity to the brush holders and if none work backwards start with the cord and then the switch etc until the problem is found.
Jun 24, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Rotary tool won't turn on or won't stay on but a second or two
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Apr 27, 2011 | Dremel Variable - Speed Multipro Rotary...
I don't know how to change the bit on my dremel multipro rotary tool . . .I keep turning the gizmo but don't see anything getting smaller or lager.
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
May 06, 2010 | Dremel Variable - Speed Multipro Rotary...
My drier 110 volts was accidentally plugged to 220
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
Variable Speed Control is faulty
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
Apr 16, 2009 | Dremel Variable - Speed Multipro Rotary...
Drills Logo
35 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
