Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
Why will my kindle not take a charge? - Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Reset Kindle Fire When it Won Turn on or Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
I can turn my kindle on but can't get any thing else to work.
Reset Kindle Fire When it Won't Turn on or Charge
www.lovemyfire.com > Kindle Fire Problems
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com: Customer Discussions: My Kindle won't charge
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 3, 2013 - If you can't see a Contact Us button on this page, then go to .... What canI do? I sent an e-mail to Amazon but have not heard anything. My Kindle is frozen and won't ...
Mar 31, 2014
How to unlock a Kindle. Lock won ...
Jan 27, 2014
Kindle paperwhite won't turn on
Nov 6, 2013
My kindle won't turn on....green ...
Dec 12, 2011
More results from www.amazon.com
Jan 16, 2016 | Amazon Kindle Fire HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
Dec 09, 2015 | Tablets & eReaders
My Kindle will not charge
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
Feb 14, 2015 | Amazon Kindle Paperwhite
My Kindle won't turn on after I charged it. I charged it because the 2 books I bought did not show on the kindle.
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
  • Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state. hope this helps
Dec 20, 2014 | Amazon Kindle 1
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Sep 24, 2012 | Amazon Kindle Fire HD
Battery will not charge
Follow these steps if the Kindle battery is not charging:
  1. Connect Kindle to a different outlet.
  2. Verify the charge light at the base of the Kindle is on.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on? Contact Customer Service.
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact customer service for in-warranty options.
Follow these steps if the Kindle Battery is not holding a charge:
  1. Turn wireless off and fully charge your Kindle.
  2. With wireless turned off, Kindle battery life should be:
    At least 7 days
  3. If battery lasts less than the time frame given above, contact customer service.
If none of this helps, or you need to contact Customer Service here are the numbers:
In the United States: 1-866-321-8851 Outside the United States: 1-206-266-0927
Thank you.
Mar 03, 2011 | Amazon Kindle Wireless Reading Device
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
60 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
