Question about Discovery Kids Long Range Text Messenger
Can we erase old code? - Discovery Kids Long Range Text Messenger
2004 Ram 2500 starts, low idle 400 rpm and stalls, any ideas?
With out see it running on a scanner. Maybe the IAC or throttle body. Does it have any codes. Did you erase codes after rebuild? Any time I do a rebuild on engines and transmission, the codes have to to erased. Other wise you are trying to run a new part on old PCM codes. Codes have to be erased.
Dec 13, 2016 | 2004 Dodge Ram 2500
Erase old videos
Ideally, you'll get a high-powered bulk tape eraser that is designed for video tapes and will work perfectly for audio tapes, as well. An audio tape eraser will work to a point, but usually won't blank them out completely since it doesn't put out a strong enough electromagnetic field to erase videotapes completely. I personally own an old Radio Shack high powered eraser and it works to erase both video and audio, as well as a demagnetizer for old color tv screens (when used at a distance...a bit too strong up close), and demagnetizing screwdrivers (the ones I don't want magnetized, that is). Hope that helps.
Apr 11, 2014 | Sony HI8-MP Hi-8 Tape
Malfunction Indicator Light stays on after problem solved
No particular reason why, some questions just get missed, sorry to say.
The reason your MIL is still on is because there still is a problem. It may be the same code, or it may be another code, but you need to scan it again for what it tells you. The light is not on from the old code that you had worked on. It is on because the computer still recognizes a fault, whether the same problem or another. I hope you had the codes erased with a scanner after the fix, or it will confuse the tech with the new code and any old codes not erased. Be that as it may, your light is still on because of an on-going problem. The computer would have recognized the original problem as not recurring and would have turned the light off. But it is still detecting a fault.
Jun 12, 2012 | 2003 Chrysler Sebring
I have added a new email address to Facebook but it did not erase my old 1, how can I erase old 1.
you can not erase old email id but you can hidden your email id please click on edit profile /setting/privacy setting and you can erase old id......
Jul 06, 2011 | Computers & Internet
I lost my keys for my 2003 rodeo
you will have to get a dealer to cut new keys to code that dealers have access to and then get them to program to car but also erase old keys so vehicle wont start with old keys
or next more expensive option is new keys, ignition barrel and door barrels replaced which are differently same coded key and locks as well as programming and erasing old keys.
Jun 27, 2009 | 2003 Isuzu Rodeo
How do you reset the service light on 2006 clk500
There is a special tool that resets the service warning called a code reader that plugs into your Mercedes computer. It reads any trouble codes and there is a button on there that erases old codes and service warnings. The tool is expensive and some garages have it and might do it for you much cheaper than the Mercedes dealer.
Jun 27, 2009 | 2006 Mercedes-Benz CLK 500
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Trying to delete all contacts
Here is how to do it on the Samsung M220, maybe it will work for your Samsung phone too:
Menu > Settings> More > Security and enter your lock code (last 4 digits of your phone number)
Select Erase/Reset
Select an option - in this case choose Erase Contacts
Nov 17, 2008 | Cell Phones
Forgotten passwords
*#7370# After typing this phont will ask for security code, Defalt code is12345
Jan 09, 2008 | Nokia 7610
Discovery Kids Long Range Text Messenger Logo
18 people viewed this question
Top Discovery Kids Toys Experts
Tre Elkins
Stan Ford
Are you a Discovery Kids Toy Expert? Answer questions, earn points and help others
