Question about Fisher Price Power Wheels Barbie Jeep
Test battery for Barbie jeep - Fisher Price Power Wheels Barbie Jeep
How to test battery?
That definetly sounds like the battery.
Here is a link to the power wheels batteries: http://www.mendingshed.com/powwheelbat.html
May 01, 2013 | Fisher Price Power Wheels Barbie Jeep
My grandaughter's Fisher Price Barbie jeep is running slow. I have charged the battery twice and it doesn't make a difference. How can I check to make sure it isn't a bad charger before
Test the charger with a ohm meter, or you could take the vehicle to a Power Wheels service station, they can test the battery for you to see if it is good.
You can find your closest service center here: http://service.mattel.com/us/powerwheels_info.asp
If you end up needing a replacement battery or charger they can be found here: http://www.mendingshed.com/powwheelbat.html
Let us know if you need any more help.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 20, 2013 | Fisher Price Power Wheels Cadillac...
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
HOW DO I CHARGE THE BATTERY ?
In the hood of the jeep there is the battery. The jeep should of came with a plug-in quick charger that fits in a general outlet. Simply unplug the battery, and plug it into your wall in the house, etc.
Sep 04, 2011 | Fisher Price Power Wheels Barbie Jammin'...
I have a powerwheels barbie jeep that does not work. The battery is good as I tested it yesterday. How do I go about fixing it? It was running fine just a couple of days ago and the next morning after...
I would suggest checking all of the connections in the wiring. Often the spade type connections can come unseated during use.
Check the following areas:
  1. Connection to the battery itself
  2. Connection to the foot switch (you may need to unscrew it from the floorboard to check)
  3. Connection to the electric motor(s) attached to the rear wheels
If the battery is older, it may have failed. If you have a multimeter, or even a simple test light, you can check to see if the battery has voltage. You're looking for around 5-6 volts. Anything below just off the charger could indicate failure.
Hope that's helpful!
Feb 28, 2011 | Fisher Price Power Wheels Barbie Jeep
I just bought a barbie jeep and the lady selling it said that it worked great. She washed it last night and now it doesnt work. She has tested the batteries and they are good. What can I do to try to fix...
Well I do hope it dries out...and works.Good luck!Let me know if you need help.I don't really trust battery testers as much as an actual reading,but with all that water,depending on the battery(s),they may be no good now.
Aug 04, 2010 | Fisher Price Power Wheels Barbie Jeep
Need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
Nov 25, 2008 | 3d Rose Londons Times Funny Society...
Fisher Price Power Wheels Barbie Jeep Logo
80 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
