Question about Frigidaire Affinity ATF7000E Front Load Washer
E47 error code front loader - Frigidaire Affinity ATF7000E Front Load Washer
5 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: no spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Washer has error code E47
I have the same problem with the E47 code. I had the service guy over and he brought a troubleshooting sheet. Basically, you must remove the door switch assembly and check the PTC (the white plug on the door switch assembly). According to the diagnostics sheet, if the switch is open or locked, then it is a doorswitch problem, but if the reading on the switch is ~ 1500 ohms, then its the control panel.
The reading on my PTC was ~ 1400 Ohms (which is close to 1500) so I ordered a new control board. I'll post again when it's re-installed.
Posted on Jan 14, 2009
SOURCE: Frigidaire washing macine ATF6000ES1 error code E47
Hi I have the same problem, Error Code 47. I went to the support page and only found manuals and the tech data sheet. Which one shows you how to get to the front door lock? Thank you
Posted on Jan 02, 2010
richroth
  • 9472 Answers
SOURCE: Frigidaire GLTF2940ES Front Load Washer - E47 then E6E
It's the main control board that needs replacing. Here is a link to the part.
Posted on Oct 20, 2012
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
LTF2940ES E47 code repair
The E47 error code is usually an indication of a failed door lock/latch. To verify this, you will need to ohm out the PTC on the door lock. If the door lock does not ohm out correctly, then it will need to be replaced.
How to test the door latch on your washer
Nov 18, 2011 | Frigidaire ATF6000ES Front Load Washer
No spin
Oct 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
E47 error
Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Jun 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Mar 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
