Problem with Sony Ericsson Walkman™ W810i Cellular Phone
Phone just showing white screen, turned off, replaced battery, sim card etc but with no result. read that this is a common problem with this model, is there anyway i can resovle the problem myself or does it have to be returned to store?
4,264 people viewed this problem
This solution has been voted best by the Fixya Commnunity
I got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
it worked for me. I got all my contacts and messages back.
Good luck
-Manoj
If you are seeing a white screen 1 of 2 things has happened. Theconnector for the LCD may have come loose or the LCD itself has gonebad.
Checking out and replacing the LCD screen on the Sony W810i is a pretty straight forward procedure.
Iwould take the phone apart and check the lcd connector first. Reseat itand try it out. If it is still white, your next step is to replace theLCD screen. This should then take care of the problem. A new LCD screenruns about 30 dollars from Ebay.
Take a look at the following link to see instructions and links to buy the lcd screen
Sony Ericsson W810 LCD Display Screen Replacement
I hope that helps out
Hey guyz i get white screen on my phone does any1 knw hw to fix it. nothing comes on it jus a white screen.
I had the same problem. I got mine from EBAY. I took it to a Cingular/ATT store. They removed the battery door and noticed that there was no "water damage indicator sticker", so they said they can only assume there had been water damage and the sticker was removed. Luckily the Ebay seller is handling the matter quickly. So what my point is, is check under the battery door for a white round sticker. White is good. Red or any similar shade indicates water damage. Otherwise goodluck!!
Try to reflash the phone firmware
Dynamicmenuerror
My w810i dropped in w.c i opened it and dry it and clean it with 95% alcohol . my phon is working but it's speed is very low rather than before what can i do?
What the hell why my screen whit how do i do this without paying please answer some one as soon as:)
White screen problem?? i saw a diagram in google it show a i.c solution. so i try it then boom it was back in condition,, no more white screen ^_^ try it
good luck....,,,,
hey when i turn my fone on it says nokia then it flashes black and white a few times then turns off again wat should i...
RAZR Phone stopped working. Messages say "Insert SIM card" and "Check SIM" . Cannot find SIM card to check contacts....
when i switch on shows white screen...doesnt switch off...plz help me ..and it doesnt show 1st boot ok..
my w810i phone is flashing white screen and cannot turn on
it is asking for favorite place which i have forgot.
my phone works great except that i cant play any games because my games folder would not open I have tried taking...
Guest screen white all time no change
Oct 05, 2008
chazzonaldo when turned on it is a white screen
Sep 30, 2008
amirkhan44 My w80i is just showing a white screen hole time. does'nt anybody how a program to fix it because its something to do about software
Jul 07, 2008
danoere2k8 when i turn it on my screen is all white how do i get it fixed nd how much will it cost
Jun 06, 2008
Guest my phone keeps blinking white light. when i turned it off and removed the battery and then put it back again it still keeps blinking. i need help!!!
May 17, 2008
yarik i have a white screen blinking
what is it?
how can i fix it?
May 08, 2008
Guest my phone also had a white screen,i took the phone back to the dealer and they sent it for repairs, ( They said it needed software upgrade) they could not repair it, and i got a new W810i. 3 months down the line the new phone has got the same fault ( screen is white) took it back and now im waiting for the feedback.
Mar 24, 2008
fez101 the phone wont start.. just a white screen pops up when i start it...
Mar 24, 2008
