Question about MSI RX300SE-TD128E RADEON X300, (128 MB) Graphic Card
Hello, I have an MSI MSI RX300SE RADEON X300 Graphic card. I want to setup a dual monitor with one primary monitor and an extended secondary monitor. The problem is that when I hit the "Identify" button in the "display properties/settings" both monitors are showing number one!! Can you help me please?
  • asim4zero Jun 22, 2009
    Thanks Wiz,
    I've already tried that. When I check the box of "extend my desktop" and click OK, The two monitors flash but nothing happen.
    Still the same problem...
  • 90 Answers
The reason you see them both as one is in the display settings you do not have it set to "extend my desktop"
Posted on Jun 22, 2009
  • Troy Anderson Jun 22, 2009
    try updating to the latest catalyst control center software from ATI. as long as that extend my desktop option is checked and not just greyed out it should work.
Hello, have Vista Home Basic. I just installed a Sapphire Radeon 7000 - Graphics Adapter - Radeon 7000 - PCI - 64 MB Problem: When I plug the monitor into the Radeon 7000, I get a black screen. If I...
Does the box say it is supported? These new 64-bit systems are still just getting going.
I tried xp64 but switched back because most of my hardware would not work.
Did it ever work? again alot of stuff is done with the 64 bit opsys.
Go into the bios, and make the new board the primary display.
In my experience, ATI needs to be primary. Just switch to PCI Primary.
If you haven't done this yet, you probably need to uninstall the software, too.
so it can setup correctly.
please rate this answer
Aug 10, 2011 | ATI RADEON 7000 PCI Graphic Card
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Trying to set up a dual monitor with onboard VGA and with Sapphire radeon x300 video card. The Radeon is taking over and not letting the motherboard vga work.
sir the mother board accept only one VGA card if you installed a new one the the other on will disabled if f you wanna run multi screen at the time just but the multi VGA dongle hub it is affordable and works fine dont need any driver buy it it`s useful affordable and have fun
May 23, 2011 | ATI Sapphire RADEON X300 SE 128MB DDR...
How can i get msi drivers with out buying driver helper
Directly from their site
http://eu.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=130&prod_no=774
Feb 11, 2011 | MSI RX300HM-TD128E RADEON X300, (128 MB)...
I have a dual monitor set up. I had a Dell monitor as the primary with a samtron secondary. Today I made a Viewsonic monitor the primary and moved the Dell to the secondary. However now the Dell switches...
You may need to check some configuration of dual monitors.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_multi_monitors_select_primary.mspx?mfr=true
http://support.microsoft.com/kb/307873
Did you change the graphic card for the primary monitor? There could be a support between that graphic card and the monitor.
Did you check the power settings about monitor and disable any power saving plans?
Dec 05, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
I don't have driver cd.because i lost my cd.
http://data.versiontracker.com/drivers/manual/ATI/wxp-w2k-catalyst-8-111-050222a-021277c.exe
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
Viewsonic vp912b lcd display will not work.no DVI
Yes you can but there should be an option in the monitor settings for DVI... Maybe if you go into safe mode and attempt adjusting settings for the ati for the dvi output, from what I hear that monitor is nice with the DVI option would be aa shame to lose that.
Dec 22, 2008 | ViewSonic VP912B (Black) 19 in. Flat Panel...
Still Not working. no output on tv.
Open the ATI software, go to "set up my display configuration" and from there you should have an option to make the TV mirror your screen exactly. If I misunderstood you and you're attempting to do something different, all the options you need to configure your display should be right within the ATI software.
Apr 06, 2007 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
No image on tv using video card.
If you open the Radeon software utility, in the advanced screen settings you should be able to set "extend my windows desktop onto this monitor" to on for the TV screen. Then all you have to do is open your video player software and drag its window across to the tv, then maximise it. If you are having trouble doing this, some video player programs, especially dvd players playing dvds will not show the picture on the tv. If you want to watch .avi files then the best free player around at the minute is DivxPlayer - go to http://www.divx.com to download. Hope this helps, please ask again if not :)
MSI RX300SE-TD128E RADEON X300, (128 MB) Graphic Card Logo
239 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
