Question about Oreck XL21 Bagged Upright Vacuum
How do I replace oreck xl21 fan?
Fan housing broke and cannot get nut off fan to replace housing, when we turn the nut the screw turns with it
  • Oreck Master
  • 932 Answers
That nut is a left handed thread, so you need to turn it like you would normally tighten it to actually loosen it. You will also need to hold the shaft at the other end with some pliers. I would suggest using a piece of cloth or leather over the shaft so that you do not scar the shaft when you grab it with the pliers. Hope this helps!
Posted on May 16, 2015
2 Suggested Answers
  • 20 Answers
SOURCE: Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Posted on Mar 27, 2009
Remove fan housing from oreck vacuum
First off take the bolt of the fan, that will allow the fan to come off of the motor alowing the fand cover to come off it takes some effort but it will come off. Best of luck, sincerely daxter.
Sep 02, 2014 | Oreck XL21 Bagged Upright Vacuum
I can't get the nut off the fan housing
You may have to slip a small screw driver into an open slot of the motor housing to provide a stop for the armature so that you can break the lock nut loose. Becareful to not cause ant damage the armature.
Jul 02, 2014 | Oreck XL21 Bagged Upright Vacuum
How to replace the belt on an oreck XL21 vacuum
There's a Pannell on the side onevno2 philips head screw remove that and there is the belt
May 12, 2014 | Oreck XL21 Bagged Upright Vacuum
Broken handle
You will need a new handle tube. You can use the included link to find a repair store near you. Oreck Store Locator
Apr 22, 2014 | Oreck XL21 Bagged Upright Vacuum
Fan housing broke on our xl21 600ecc
If you take it to an Oreck dealer for repair you will probably get both because the fan housing usually comes with a new fan. Usually a fan housing will only break if something was picked up that the blades flipped it into the housing with enough force to crack it. You may find that depending on the dealer it may not be covered under warranty. I work at a dealer on weekends and work on these machines and have seen this frequently, I would recommend replacing both if you are able to get them separately.
Mar 27, 2014 | Oreck XL21 Bagged Upright Vacuum
Oreck xl 21 fan housing has new design. willit stillfit my older vac
It should. You can call Oreck and talk with them and give them the serial number off your vacuum and they can look it up and tell you for sure if it will fit or not.
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
I have an oreck xl and the vaccum wont hardly push. Is it the belt? The brushes aren't turning when I lay it on it side. How do you replace the belt? If you can give detailed instructions I would so...
On the side of the head you'll see a removable plate with one screw. Remove the screw and slide the plate towards the front until it's off. You'll see the belt.
Nov 05, 2010 | Oreck XL21 Bagged Upright Vacuum
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
FAN
Take off the bottom plate, remove the screws for the motor and fan chamber, remove motor from fan housing, remove the nut for the fan. You may have to lock down the armature if the nut is too tight. Replace fan and reinstall motor into the fan housing and reinstall.
Apr 10, 2008 | Oreck XL2600 Vacuum
Oreck XL21 Bagged Upright Vacuum Logo
116 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
