Question about Dyson DC28 Animal Bagless Upright Vacuum
Cub cadet 1027 lawn mower will not backup - Dyson DC28 Animal Bagless Upright Vacuum
I ran over the cord to the vac with my lawn mower ,I need to replace the damaged cord with a new one. How do I remove the old cord?
You need to remove the screws that are in the location of where the wire goes into the vacuum. Then you will see a cord grip and connectors for the wires.
May 13, 2016 | Craftsman 2.5 gal, 1.75 Peak HP Portable...
How to replace the power cord?
Follow cord to where it goes on mower, then connect the wires the same way you took them off. but be sure to turn power off!!
Can I convert an electric Lawn mower to cordless
Are you serious! It will be impossible to get a mains powered lawn mower to run with battery power!!
Aug 26, 2014 | Abranet Mirka Abranet/Black and...
2011 mtd yardman pusher lawn mower.Need complete recoil starter assembly
order it online Im sure that the parts should be available through briggs and stratton or yardman inc
Jun 28, 2014 | Dewalt Vacuums
I need a recoil starter assembly for a MTD lawn mower 2011 with a B&Stratton 158cc 550 series engine.The model # is11A-A18M055, and the serial# is 1211KA0057
The model number that you posted does not apply to the motor. The motor series that you posted is for a vertical motor that does not match the model. Can you supply more information?
Jun 20, 2014 | Dewalt Vacuums
Why does the mowe blade on the Cub Cadet 1517 keep kicking out
This is the Dyson section! Please repost in correct section. Thankyou.
May 04, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Diagram for wiring and fuses for 2005 toyota tundra
Your post shows a picture of a vacuum and you are in the lawn mower section talking about your Tundra..
Oct 02, 2013 | Vacuums
A lawn mower black hawk
I have got a little yell o steam cleaner it is getting up to pressure but there is no steam coming out of the nozzle how am I able to fix this can some one help me with this matter please
Jun 14, 2013 | Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Lawnmower
There may be a thermal fuse fitted to the motor, sometimes they reset when they cool down. Sometimes they are a one shot fuse, when they blow the have to be replaced.
There may also be a reset switch on or inside the operating lever/switch.
Have you also checked the operating switch/lever for a bad connection or a wire come loose.
Mar 31, 2008 | Vacuums
Dyson DC28 Animal Bagless Upright Vacuum Logo
19 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
