Question about Lexmark X Office Equipment & Supplies
How to reset replace pc kit error
Reset replace pc kit error
Reset Replace Maintenance Kit warning error on Kyocera FS1370DN
Press MENU on device, scroll to ADJUST/MAINTENANCE, press right arrow and you should see NEW MK.
Press OK twice.
Oct 09, 2015 | Kyocera Office Equipment & Supplies
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Dell printer 2330d asking to replace pc kit
Hi, you can find it on amazon, here: Amazon com Dell printer pc kit I hope this helped you. Have a nice day
Feb 04, 2011 | Computers & Internet
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
Photoconductor kit
you must reset the error message; find the explanation in the photoconductor kit package
Sep 29, 2009 | Lexmark E238 Laser Printer
I have just fitted a new image fuser kit to our HP 4650 laser printer. However, the error message "replace fuser kit" reappeared on switching the printer back on. Any ideas. Have taken it out...
To reset the fuser count, do the following:
1 Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight RESETS.
5 Press to select RESETS.
6 Press to highlight RESET SUPPLIES.
7 Press to select RESET SUPPLIES.
8 Press to highlight NEW FUSER KIT.
9 Press to select NEW FUSER KIT.
10 Press to highlight YES.
11 Press to reset the fuser count.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | HP Computers & Internet
Lexmark E340 printer gave error " Replace Fotoconductor" I replaced the fotoconductor, but it still gives the same error
Reset Procedure(s) after putting in new Photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Aug 28, 2008 | Lexmark E340 Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
10 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
