Question about RCA Televison & Video
Rca L42wd22yx5 Red light is on but TV wont turn on
jtrag
  • 112 Answers
SOURCE: RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Posted on Jul 21, 2009
mpaint
  • 36 Answers
SOURCE: RCA L42WD22YX5 TV green light but no sound/picture
Recommend opening it up and looking at the power board and see if there are any visible Bulged or leaking capacitors.
Bad caps are a major source of computer and LCD no post problems.
If you find em, then just find replacements with the same uF and voltage and solder them out/in.
Posted on Jun 28, 2010
budmrtn
  • 11361 Answers
SOURCE: 42in lcd TV L42WD22YX5 WONT
You need to do some troubleshooting first since it can be any one or more of the boards that failed. Please read my guide below before DIY.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Posted on Jan 12, 2011
walesarumi
  • 6993 Answers
SOURCE: rca tv modle #27v414tyx8. wont
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 12, 2011
walesarumi
  • 6993 Answers
SOURCE: model l42wd22yx5 ser.
I hope this helps.
Good luck.
Posted on Apr 03, 2011
42in lcd TV L42WD22YX5 WONT TURN ON THE GREEN LIGHTS ON,BUT NO PICTURE.
Jan 11, 2011 | RCA L42WD22 42 in. LCD Television
My RCA tv turned off in the middle of watching it and now it wont turn back on.red light comes on and tv makes clicking sound but no picture or sound.sounds like it turns off again.
Sounds like the Horizonal Output Transistor Shorted, Also on many RCA sets the Flyback Transformer is bad to go and short the HO Transistor
Oct 09, 2010 | RCA Televison & Video
20f420t wont turn on, rca tv
power supply aka high-voltage transformer is bad.
Mar 23, 2010 | RCA 20F420T 20" TV
RCA LCD TV L42wd22YX5 - Gets unusual signal to all inputs
Tries Ebay.com,Shopjimmy.com for used signal tuner main board.
Jan 03, 2010 | RCA L42WD22 42 in. LCD Television
Dec 28, 2009 | RCA L42WD22 42 in. LCD Television
RCA l42wd22yx5 green screen when on HDMI... Still get sound
We had the same problem. What we did was unplug our DVR box from Comcast to reset it and plugged it back in and the picture came back.
Dec 05, 2009 | Televison & Video
THE tv L42WD22YX5 turn on ok , apear unusable signal no sound no video what problem is_
your mainboard is failing and will need to replace this company as well as many others do not sell part seperatly only at board level you can try shopjimmy.com or call a local shop to help you
Dec 02, 2009 | RCA L42WD22 42 in. LCD Television
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
Tv wont turn on, red flashing light
FLYBACK & HORIZONAL OUTPUT SHORTED
Apr 11, 2009 | RCA 32V524T TV
Televison & Video Logo
15 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
