Question about Dometic RM2652 Refrigerator
Food freezes in bottom, no stat adjustment - Dometic RM2652 Refrigerator
    Top Expert:
  • Dometic Master
  • 8,177 Answers
Move temp sensor up into coil
Posted on May 25, 2016
Food in bottom of refridgerator is freezing
If that is the case you will have set the temperature in that compartment of the fridge too low. Adjust it little by little until the freezing problem is solved because the bottom of the unit will eventually not get to freezing point.
Jan 28, 2016 | Refrigerators
Fridge is freezing food
you can usually adjust he thermostat inside the fridge.... can be located anywhere. Try checking the manual if you still got it.
Apr 01, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have a fridge on top freezer on the bottom. The fridge is freezing food and the thermostat is only set to 4. How can i fix this? And does it have anything to do with how much is packed into the...
No it does not have a thing to do with what is in it, as long as you close the door without needing a running start you cant push too much in it. The thermostat that controls the actual temp in BOTH freezer and fresh food is in the freezer adjust it to a higher setting, the t-stat in fresh food controls amont of air flow but not the tempature.
Also if ya have not done it in a while remove the grill below the freezer and clean the dust from there so it can breath easier
Gene
Aug 03, 2011 | Amana ABB1927DE Bottom Freezer...
The food in the refrigerator section freezes. we have lowered the temp control slide to the very bottom but still the food is freezing. Sherri Eley
perhaps try using the adjustment the opposite way -- to be sure you are not going cooler, instead of warmer for your adjustment?
Bets regards
Ck
Jan 17, 2011 | Dometic Refrigerators
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Food freezing in refrigerator storage bins
produce has more water in it to freeze. Try turning down the temp in the fridge part of the unit you may try putting a termometer in there to gauge where it should be adjusted to, about 38-41 degrees is a safe temp for keeping food.
May 27, 2009 | Refrigerators
Food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Jan 25, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
FFA70
these machines commonly do not defrost sometimes an intermittant fault
remove back panel from freezer and if im right, the pipework will be iced up especially at the top. de-ice carefully with a hairdryer but don't blow hot air on the stats mounted on the pipework. turn on and check fan runs as well
Jun 29, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
