Question about Sony DAV-S500 System
Sony DAV S500 transistor output problem
Transistor problem
4 Suggested Answers
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Posted on Jan 15, 2008
SOURCE: COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Posted on Jun 04, 2009
  • 15 Answers
SOURCE: I want to connect an external DVD player (Samsung
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
ANY QUIERIES MAIL TO ME
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Posted on Jul 16, 2009
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Not getting any sound box just keeping saying protect, protect
hello it sound like the output transistor could be the trouble, or just may be a case of try joints or swelled capacitors all the best.
regards
shaun
Sep 09, 2010 | Sony DAV-DX255 System
The DAV-S300 tray does not open when the eject button is pressed. Please help! I have checked the manual and it says when locked is displayed on screen contact Sony but locked is not displayed on screen....
There is a transistor on the bottom of the main pcb assy which shorts out causing no voltage to the open/close motor. This is a common problem with this model.You may able to see this transistor as it will look burnt.it is a smd transistor
Apr 16, 2010 | Sony DAV-S300 System
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
We have an error message of c81 and the dvd will not open can you help?
You have a brunt transistor and open resistor on the bottom of the board next to the dvd mechism.there is a update where you change to a better transistor.This requires taking to a Sony servicer, as they are well aware of this updating
Sep 26, 2009 | Sony DAV-S500 System
I want to connect an external DVD player (Samsung DVD-1080P9) to my Sony DAV-S500 system
you have
analog input X 1.
Jul 11, 2009 | Sony DAV-S500 System
Oct 15, 2008 | Sony DAV-S500 System
Protect
The protect message indicates a problem was found inside the amplifier. The output transistors are most likely shorted and need to be replaced. This is a fairly simple repair and should cost about $40 in parts plus your local labor charge.
Dan
Mar 18, 2008 | Sony DAV-S500 System
Dec 30, 2007 | Sony DAV-S500 System
Error with DAV-S500
Sony DAV-S500 error c-81: On the rear side of the DVD board connected to the DVDv drive is a power transistor Q002 that is shorted BASIS-EMITTER. The device is an Toshiba 2SA1213Y (PNP transistor 1$) Replace and your DVD works! good luck :) Foxi from Budapest, Hungary, Europe
Jun 11, 2007 | Sony DAV-S500 System
Sony DAV-S500 System Logo
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
