Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
The red error light is on and the display says check fax mode
  • Konica Minolta Master
  • 6,161 Answers
Is the fax line a analog line can not use a digital line, and is the fax line plugged into the Line and not the Tele jack
Posted on Dec 30, 2015
I have a brother fax machine mfc8220, its displaying in red with error message remove original and the press stop. no paper jam or any paper inside.
Dear Miro
Pl. check the ADF section any of the sensor may clogged.
At least two sensors are there.
thanks.
Feb 26, 2015 | Brother MFC-8220 Fax
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Error Code 244
It seeme the fax no you are trying to send fax does not receive fax in higher speed or might be it is a older fax machine than the one you have.
Try reducing the fax speed on your machine and trun off ECM mode.
Press Menu / Setup> Press the right arrow key till you see advance fax setup> and press Ok> Again press the right arrow key to locate fax speed> and press Ok> and reduce fax speed to slow> Press Ok. and cancell to come back to the main screen.
To disaable ECM mode>
Press Setup .
Press the Down arrow repeatedly until Advanced Fax Setup displays.
Press OK .
Press the Down arrow until Error Correction Mode displays.
Press OK .
Press the Right arrow > until either OFF or ON displays.
Press OK .
Send another fax to verify that the ECM is enabled or disabled.
Check the link bellow for a detail of all fax error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=391194
Good Luck
Sep 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
There is a big trouble
all faxes use automatic fallback sytem for dropping the speed as well as the machines communicate on the highest common speed therefor you don't need to set the speed. Apart from the situation if your phone line is disturbed and not receiving faxes and giving communication errors.... happy faxing omnipresent
Nov 08, 2006 | Xerox FaxCentre F110 Plain Paper Laser
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
