Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
1995 gmc jimmy where is the turn signal relay cannister located
    Master:
  • 519 Answers
Where is the turn signal flasher relay?
If you have the owner's manual there will be a fuse box diagram and it should include all relays. If not you can purchase a Haynes manual that will also include the diagrams. Most likely the flasher is in the high amp fuse box under the hood and there is usually a diagram on the cover or in the fuse box itself.
Feb 14, 2011 | 1996 GMC Jimmy
Clicking after using turn signal
You may need to replace your turn signal relay. It is located behind your glove box.
Apr 26, 2010 | 1999 GMC Jimmy
Where is the turn signal switch located
The turn signal switch is located in the steering collum.
Feb 02, 2010 | 1995 GMC Jimmy
Turn signals dont work but bulbs work as flashers
your flasher element has gone out , it is on the fuse box read the cover and it will tell you which one it is replace
Aug 07, 2009 | 1995 GMC Jimmy
Where do i find the flasher on my 1995 gmc jimmy
the flasher is right below the radio,under the dash .it take 3or4 screws to take off panel.both flashers are under there.one for your 4 ways,and one for your turn signal.if your four ways work you can fill the flasher to determin which is witch. mine the four ways was on the left,turn signal on the right.they are not in the back of glove box.ther is apanel there with three relays but not for your turn signal.thank u gm jim.u helped me find them.
May 07, 2009 | 1995 GMC Jimmy
I have no turning signals on my 1995 jimmy. The fuse is good and the four way flashers work. If the flasher was bad wouldn't the little turning signal light still light up on the dash? I'm not sure where...
there should be a set of huge fuses located on the top of the firewall under your hood. Look for a burnt fuse there or look for an outside fuse panel located close to the fender wall under the hood. Some makes and models also wont allow the lights to work in the dash even if there is a blown signal bulb.
Mar 31, 2009 | 1995 GMC Jimmy
Flasher relay won't stop
if you turn the signal off then the turn signal switch is bad
Mar 26, 2009 | 1998 GMC Jimmy
1995 GMC Jimmy signal light function not working
ASE mechanic here:
trying checking the turn signal flasher, the fuses, if all work fine, most likely cause is the multi-function switch.
Jan 26, 2009 | 1995 GMC Jimmy
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
108 people viewed this question
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
