Question about Poulan "Poulan" Push Mower
Where is the air filter in a poulan pro 550 - Poulan "Poulan" Push Mower
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
  • 302 Answers
SOURCE: where are the oil drain plugs for a poulan pro 550
under the deck above the blade. It is probably a square head pipe plug
Posted on Oct 17, 2009
rycgl
  • 1545 Answers
SOURCE: how do i clean the air filter for my poulan pro
You can only clean it if it has a replaceable (fabric-type) filter...If it is paper, it is disposable and will have to be replaced if bad.
Posted on Jun 13, 2010
  • 59 Answers
SOURCE: I have a poulan pro
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Posted on Sep 25, 2010
Knucklebstr
  • 222 Answers
SOURCE: poulan pro w/ 550 series
Your carburetor needs a good cleaning or a rebuild kit, depending on its condition once opened up. There are tiny holes (jets) in there that easily get clogged or gummed up with today's crappy gas (ethanol). This is the problem with 90 percent of the machines I work on or fix. If you don't know carbs, then I recommend you take it to a professional and have the carb done (30 to 40 USD, probably), but it should run like new, once this is properly done. If you are a "do it yourselfer". then you can find plenty of videos on youtube to help you get started. Just pay close attention to what goes where when you take the linkage apart. Trust me, do not leave it to memory; take photos. Best of luck to you.
Posted on Jul 02, 2011
Testimonial: "Much appreciated. Giving me an idea of what to look for as well as where I can go for further information is extremely helpful. Thanks. -Jake Towley"
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro 550 series B&S 158cc push mower. it sounds like a moved the choke when I went under a bush, because its running at a lower rpm. However, I can't find a manual choke.
The first thing I would do is , look at the front of the mower. On your front right side is your air filter. Remove the air filter, I believe that coincidently your air filter got to the point where it couldn't breathe anymore, meaning clogged to the point of choking. You can tell by putting it up to sun light and looking through it. If it's very very dirty , it needs to be changed. Also if there is a choke, it would be just behind the air filter. If it blocked off the end of the carburater then the choke is on. If this is the case then follow the rod that moves the choke. Possibly it was bent when you went under the bush. I believe you will find that your problem lies with a dirty air filter.
Jun 14, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
How do i clean the air filter for my poulan pro 550 series
Jun 10, 2010 | Poulan Pro PR550N21RH 21Inch 190cc Briggs ...
I have a Poulan PRO 550 series that I just bought 4 weeks ago. It won't start. The oil is at a good level. There is plenty of gas. Everything was checked and it still won't start. I am so disappointed. Has...
There are several possibilities for not starting. Water in the gas, Carburetor jet clogged ; Spark plug needs replacing, air filter needs replacing, or you have old gas. Or if you have hit something the flywheel key may be sheared. Hope this helps.
Good day.
Oct 16, 2009 | Poulan Pro " Pro" Self Propelled Mower
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan "Poulan" Push Mower Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
