Question about Toshiba e-Studio 350 Copier
Sharp how to close the finisher door - Toshiba e-Studio 350 Copier
What is the finisher front cover? And how do I close it?
You are standing in front of it, the machine has sensors that sarround its operating peoperly therefore pay attention to its claims. closing is simply closing when you open the front door of the machine same way close it firmly but gentle, make sure everything inside is properly set accordingly to mini instructions inside the machine follow them they will guide you. The machine has atleast three doors the front and two side doors. look for them and just make sure they are closed nicely and properly.
Aug 01, 2011 | Sharp AR-M350U Copier
Microwave heats fine, finishes timed amount, press end, open door and microwave keeps going like door is closed. Is this a malfunction that requires a recall? Sharp Carosel
Hi - I'm not sure about a recall but certainly not safe to use as you have exposed yourself to radiation if the oven runs with the door open.
Common sense must prevail here - there is a high possibility the door switch(s) is faulty - have it checked thoroughly by a serviceman and check with the company if there were known problems with the particular model in question.
I find it extremely rare for something like you have experienced to occur - have never come across this problem ever - the microwave circuits are meticulously designed to have three door switches to eliminate the very problem described by you.
A but concerned...
Jul 13, 2011 | Sharp Ovens
After I fix a code problem with my Sharp AR505, how do I clear the fault code? The code is an F1-15
The F1-15 code deals with the finisher exit tray. Does the tray move up and down when the copier is turned ON? The way to reset the code is to open and close the finisher doors. There is a gear pack that drives the tray. I would look at the motor & connections. I believe both gear packs are the same... I know it is not easy, but you are going to have to take the finisher OFF and take a closer look at the part's on the inside for a broken part. There are also some up dates on the finisher.. Good Luck
Feb 19, 2010 | Sharp AR-M237 Copier
Sparp R 930 not heating, turntable not turning
I just repaired mine with the same symptoms. I found that the bottom microswitch on the door (there are 3 switches) was faulty. It started as open, when the door closed, the switch closed (good), but when the door was fully closed the switch was open again. I went to Electronic City with the switch in hand, they found me a duplicate that cost me $2.50. BTW - you must take out the door switch assembly, 3 screws plus wires, in order to work on the switch. Also, put the assembly back in so that the door latches close/open the switches correctly. -jk
Jan 14, 2010 | Sharp R-930AK Convection/Microwave Oven
Screen says close finisher door, where is finisher door?
The stapler unit on the exit side, there may be more than one door. -Carl
Dec 03, 2009 | Sharp AR-651 Copier
Sharp mx2300n is telling me to close the finisher unit and finisher covers.....taken it out and put it back in again and its still saying the same thing?
If you have open and closed ALL covers then you probably have a bad door switch. Try turning the copier off (both power switches) and on again. If that doesn't work then you should call a qualified technician to look at it.
Oct 17, 2009 | Sharp MX-2300N Color Copier
Message on sharp ar501 copier. close finisher unit and finisher covers.
Check the finisher covers sensor or microswitch.or anymore mechanical components deformation.
Sep 30, 2009 | Sharp Office Equipment & Supplies
Unit says ''close finisher unit and finisher covers''
I have the same issue. Did you ever find a resolution?
Apr 06, 2009 | Sharp Office Equipment & Supplies
Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Aug 12, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
16 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
