First be sure that you are bare foot when using the scale. If you are not making contact with the metal sensors on the scale's platform the scale will read Err 2. The way the scale is able to measure your body fat and body water % is by sending a small, unnoticeable electronic signal through your body. Also, be sure the scale is on a flat, stable, hard surface while in use.
If you are bare foot while using the scale, and you are still receiving an Err 2 message, please fill out the form at this link (http://www.escali.com/index.php?p=warranty) and one of our customer service reps will contact you within approx. 24 hrs with instructions on a fix or replacement.
Questions, contact @escaliscales on twitter or call 1-800-467-6408.
Here are the basic ERR messages and their meanings:
Error 0: Initialization
Error 1: Instability (scale is on an uneven surface ex: carpet)
Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
Error 4: Body fat is out of range
Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do?
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
Remove the battery from the scale.
Sit the scale on a hard surface floor.
Step up onto the scale, stand still for about 5 seconds and step off the scale.
Re-install your battery.
Place the scale back on a hard surface floor.
With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
Wait for the scale to turn off again.
Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
