Question about Magellan RM5295T-LMB 5" Smart GPS, Cloud Connected, WiFi
Reset magellan gps
Cannot access gps signal
5 Suggested Answers
SOURCE: Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Posted on Jan 30, 2008
sosa28
  • 53 Answers
SOURCE: Magellan Maestro 3100
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Posted on Nov 26, 2008
  • 1111 Answers
SOURCE: Magellan Roadmate 2000.. No GPS signals
make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then locate the reset button on the left side bottom of the gps and use a paper clip to depress the reset switch...it should restart on its own..take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update and follow the instructions..you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Posted on Jul 18, 2010
  • 1111 Answers
SOURCE: The gps is a magellan RoadMate 2000. It does not
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
let me know if you need further help
Bill
Standing Member of G.O.T.
Posted on Nov 16, 2010
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Magellan 4700 stuck at acquiring signal. nothing else happens. is there a fix?
on some units this may take awhile to load depending on the area you are in. mine does the same thing. if it really never finds the signal and it does this continually then try to reset it
Aug 16, 2011 | Magellan Maestro 4700 Car GPS Receiver
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
bill
Jul 16, 2010 | Magellan RoadMate 2000 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
I have magellan 700 roadmate .it is not take signal.it just search and search.
I woud do a reset on the gps device....I have attached a link to the manual for the Roadmate 700....http://www.starbatteries.com/maro700vegps.html
You are going to look for this
Magellan RoadMate 700 Vehicle GPS View the product manual [Download- PDF, 1MB]
Good Luck
cbinny1
Oct 20, 2008 | Magellan GPS
Magellan 310 Signal Won't Lock In
Turn on the power while holding down the right arrow. This will reset the unit. You will have to reset the location, date, and time.
Nov 26, 2007 | Magellan GPS 310 GPS Receiver
Magellan RM5295T-LMB 5" Smart GPS, Cloud Connected, WiFi Logo
205 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
