Question about Saeco Coffee Makers & Espresso Machines
120v plug in 240v country - Saeco Coffee Makers & Espresso Machines
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
To tell you what you must do we need to know exactly what is the type of your machine .Also we must know except volt machines watt and hertz.We also need to know the hertz of the country.
Posted on May 08, 2014
  • Mark Ennes
    Mark Ennes Sep 20, 2014
    When I lived in Germany, we used a device called a transformer that converted the 220 to 110. You then plug the unit into the transformer.
Plugged it in and boom came the sound never worked is it because we in India use higher voltage.
Unless the device is switchable from 120V to 240V, you must use an inverter to operate it. Plugging a 120V appliance directly into a 240V outlet will always result in smoke and flames.
Apr 26, 2016 | Food Processors
Can I use this thermostat to control a 310w, 120v heat lamp load?
Voltage & Amperage are two different things. Check how much amperage iheat lamp requires. Rich
Apr 13, 2015 | Dimplex ETS610A1 Electronic Line Voltage...
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
I HAVE THE WHIRLPOOL LER4634JQ0. IT SAYS 120V/240V. CAN I USE IT AN APARTMENT ?
Is your apartment wired with a 240V outlet? Ask your landlord. A regular outlet is 120V. Electric dryers use 240V, thus where you are plugging the dryer into has to be a 240V outlet.
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool LER4634J Electric Dryer
Can you put a aussie 240 volt plug on an US battery charger
Look at the specs on the label, if it says that the charger is capable of taking a 240v input then you can change the plug and use it at 240v with no problem. If it says 120v then you won't be able to, you'll want to use a transformer or some other 240 to 120v supply.
lp
Dec 26, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
No hot or warm water what is the voltage reading susposed to be on the heating elements? I have 122 volts on each terminal on both elements but no action, what am i doing wrong?
If water is totally cold, then upper element is not getting 240V. Since element tested for 120V, then that says upper element is burned out, upper thermostat is bad, or circuit breaker is bad.
Best thing is to buy multimeter and do 30 minute troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Also read information below for understanding how water heater works.
Testing elements for voltage can be misleading.
If water heater has 2 elements, then tank is 240Volts.
240V water heaters have 120V on each element at all times.
So elements have hot 120V power, but they are not turned on until the circuit is complete with 240V.
Open following links to read specifics about 120V and 240V
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
240V is made from two 120V Hot wires from breaker box.
Each 120V line from breaker is called a 'leg.'
So 240V circuit has two legs, and both legs need to be turned on to complete 240V circuit.
Water heater thermostats turn off only one leg.
The other leg is Hot all the time.
So when you test screws on an element, for example test between a screw and any bare metal part of tank, then the screw will always show 120V.
That is just one leg of the 240V circuit.
But the 240V circuit is not turned On until both legs are connected.
Every residential circuit needs two wires to complete the circuit, and in the case of 240V, those two wires are both 120V.
When the thermostat turns on, it turns on the second leg to the element and that completes the 240V circuit.
http://waterheatertimer.org/How-it-works.html
Dec 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
JBL on stage II speaker doesn't work
If your 120v unit is not marked for use with 220-240v and you plugged it into such a socket (even once), you probably fried the AC adapter and will need to get a replacement.
Jan 21, 2009 | JBL On Stage Micro Portable Speaker Dock...
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
