Question about Tablets & eReaders
Broken glass Got the Glass cracked
4 Suggested Answers
  • 108 Answers
SOURCE: display crack
Honestly it may cost less just buying a new laptop. Screens can cost more than a new laptop =[
You can use an external monitor if you do not plan on moving the laptop around too much.
G'luck
Posted on Nov 11, 2008
SOURCE: cracked glass screen but display remains clear
see
http://www.fixya.com/support/t2749865-got_crack_screen_hp_tablet
Posted on Jul 26, 2010
TechyDrood
  • 2072 Answers
SOURCE: broken glass
Yes, although it's not cheap nor easy to replace. ifixit.com
Posted on Nov 19, 2013
My screen looks like it's broken but the glass is not cracked I think it my be a video problem how can I find this ? A reset ?
If it looks like broken in all apps then what is broken is the lcd screen itself and the glass is not.
Mar 10, 2015 | Tablets & eReaders
Is it easy to replace a cracked screen on a acer iconia B1-710?
I've done several Samsungs, a couple of Apples and a Nextbook. I've never done an Acer but I'm guessing it's not too difficult.
Look up YouTube videos on the subject. You can probably find one for the exact device you have.
If the image on your tablet still looks perfect but the glass in front of it is cracked, then you only have to replace the digitizer glass. The screen is behind that. If you have to replace both, try to purchase an assembled package because it will be easier.
Typically, the image screen is fastened to the tablet frame with double-faced tape around the edges. Then another layer of double-faced tape goes around the perimeter of the image screen and the digitizer is stuck onto that. Getting things apart involves using a hair dryer and several little plastic pry tools (some of which look like pry-bars with a handle and some of which look like guitar picks) to separate the glass parts from the heat softened adhesive. I've found that having several single-edge razor blades is also handy as long as you don't slip and push it into your finger.
When you replace the adhesive between the screen glass and the digitizer glass, make sure you don't leave any gaps in the adhesive. Pressing on the front digitizer glass oil-cans it in and out and if you leave any gaps in the adhesive, dust will get sucked in between the sheets of glass.
By the way, I will NEVER do a Nextbook again--at least I wouldn't replace just the glass. They don't use double-faced tape at the factory. The glass was somehow bonded directly to an aluminum frame. Much of the glass I scraped off the frame only came off when pulverized into powder. I would buy the replacement glass already bonded to the aluminum and just snap that on. Probably wouldn't be cheap.
Feb 28, 2015 | Acer Tablets & eReaders
How do I get order new window fow my coby 7 tablet it window crack wont open serviceso it need replace window glass.
Go to Google or you tube and enter the information of you device that you intend to fix. I did it when my clr get broken , I get a video step by step. Good luck.
Jan 04, 2015 | Coby kyros Tablets & eReaders
How can you fix a pandigital tablet screen that is cracked?
Sounds like a rough one. Repair the crack? @ things ... Replace the glass and or the screen.You do not want to get any glue or used for that purpose. The glass is to protect the screenso, it would be best to look into replacing the glass. It might be part of the screen itself.
Good Luck-Ned-
Jul 23, 2014 | PANDIGITAL Planet 7" Color Touchscreen...
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
May 20, 2014 | Tablets & eReaders
Cracked glass on my tablet
What do you need help with? This is a technical support site, you can't send in your device to one of us to get it fixed.
Mar 18, 2014 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Cracked tablet
Sorry, but I'm afraid you have more than a cracked tablet. If it will not take a charge or turn on, you have a broken tablet that younwill either need to repair or replace. Most times, it will be less expensive to replace a tablet that is in such disrepair. Good luck....
Dec 30, 2013 | Tablets & eReaders
Broken glass tablet can one replace this with
U can buy the glass repair kit for it plexiglass isn't the way to go fix write
Oct 16, 2013 | Tablets & eReaders
How do you repair a cracked screen?
I don't own one, but I'm guessing it has a glass-like layer over an LCD display. The first step would be to figure out if it is the glass that is cracked, which I'm assuming is the case, or if the LCD is what is broken. In either case you will need to find a replacement part. I've had good luck using http://froogle.google.com or eBay to find similar replacement parts. Just search for your devices model number plus screen. After you have the part you need it should be a simple disassemble, replace, reassemble procedure. Hope this helps.
May 10, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
10 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
