Question about Garmin StreetPilot 2720 GPS Receiver
Cannot locate sattalites
Was working fine and turned it off for 4 days and now it will not locate sattalites.Why
Where can get a remote control model rc n38 for sinotech tv
Walmart universal remote all in one will work with just about all TVs made in the last 8 years I have three of them an all work TV DVD stereo cable boxes an sattalite as well
Nov 12, 2014 | Televison & Video
I need instructions to program a phillips iniversal remote
It is very difficult to describe all setup instruction here by this window. If you wish to get more about it, check this link.
Feb 12, 2013 | Philips Magnavox Learning Universal Remote
My 99 Chevrolet silverado 4wd not working.ive replaced the dash switch and still nothing .when I turn the key the 4wd switch lights stay on for a split second then goes off. What else should I try?
I have run into to this problem many times on these trucks, i have seen your problem and also where the 4wd high light wont work but 4wd low and 2wd work fine and the 4 wheel drive works fine. on your truck i will bet its the transfer case selector motor.
the motor is what turns the lights on when in the selected mode which goes through the 4wheel module under the dash, this sounds like a bad selector motor and that where i would start. this motor is located on the transfer case, it bolts to the rear of it.here is a picture of it to help you locate it. good day.4_14_2012_12_37_13_pm.jpg
Apr 14, 2012 | 1999 Chevrolet Silverado 1500
1997 GMC Savans 35500, Rear Air only warm air
well what I see you have two problems with you A/C ..1- if the compressor is cycling very fast , the system is probably low in freon , this ban takes like 4lb of freon, now, 2-if we have the right amount of freon and the rear A/C don't work and all the vents are working fine back there for sure the problem is the expansion valve located close to the rear evaporator , that valve get stock open allowing to much refridgerant get in to the evaporator and no cooling at all ,in the back,... you can also have a bad low pressure switch located on the accumulator, making the compressor cycling very fast ..the first you have to do is check the pressures if they are OK , change the low pressure switch..then go to the second problem
Aug 02, 2009 | 2003 GMC Savana
My toshiba sattalite A110 battery will not charge.
Remove the battery from the laptop reinstall it and plug in the charger this will start the charging of battery if still doesnot recharge replace the battery
Jul 22, 2009 | Toshiba Satellite M35X-S149 Notebook
My roadmate 700 wont pick up sattalite until 1 or 2am
Install this update and take out into a clear, open area to create initial SAT contact. This will set your location and map sat locations closest to you.
http://www.magellangps.com/support/chooser.asp?prodid=955&supportid=529
Oct 13, 2008 | Magellan GPS
Playing a video tape
You can change to the vidio channel, if you have one; eg.3 or 4. If you have sattalite or cable, on the remote you press t.v. and then source. You may need to press it more than once, depending on the t.v.
Dec 08, 2007 | Sylvania 6413TC 13" TV
TV will not turn on
check the items listed in the image to locate the 5 blink error. good luck.
Jan 03, 2007 | Sony KV-36FS16 36" TV
Garmin StreetPilot 2720 GPS Receiver Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
