Question about Sony Playstation 3 (PS3) Console
2 LIGHTS ON CONSTANTLY WON'T LOAD GAMES
I HAVE 2 LIGHTS ON MY CONSOLE THE BLUE ONE AND THE GREEN. THE GREEN LIGHT WON'T GO OFF AND IT SAYS NO SIGNAL ON THE TELE
  • 490 Answers
Make sure there is no disc inside first as stupid as it sounds people do do it, when you go to turn the ps3 on hold down the eject button b4 you press the power one then turn the power on whilst stil holding the eject button, if this does nothing when you turn the ps3 off hold down the power button this should reset its settings which can be the cause of no display on your tv
Posted on Jun 23, 2009
How to Stop the Red Ring of Death on Xbox?
Hi Carolyn,
- notice poor game performance (if your games start taking a long time to load, or they become stutter or crash, it may be indicative of a looming hardware failure)
-notice poor system performance (if your system locks up, even when not playing games, this is a sign of hardware failing).
- understand the different light codes
Green-green lights indicate that console is powered and operating properly
1 red light-Hardware fault. Usually followed by E74 code on TV
2 red lights-overheating error. If the console becomes too hot, the system will shut down and display this light code
3 red lights-general hardware failure also known as the red ring of *****
4 red lights-AV cable isnt currently plugged in
If you do get red ring of *****:
- purchase a fix kit
-have console professionally fixed
-have console sent in to microsoft
-Prevent red ring of *****-understand what causes hardware failure
-keep your system in a well ventilated area
- avoid long gaming sessions
-keep system horizontal
-avoiding stacking items on xbox
-clean gaming area
-dust xbox
Oct 20, 2016 | Video Game Consoles & Games
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 30, 2014 | Vehicle Parts & Accessories
My wii console won't turn on.. The light shows a
Hi this can mean a fault with the console, usually if its under warrenty nintendo will replace it with a refurbished console for a cheap price
Apr 18, 2012 | Nintendo Video Game Consoles & Games
When i turn on the ps3 the light blinks blue and green then the ps3 instantly shut off and then the game light blinks red constantly
Yes this is the red light or YLOD you need to stop the heat build up in order to play your games, use a good guide or send it in and get it fixed.
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
My wii turns on and the television says that there is no signal but my turns on because y see the power buttons light turn green. Also the wii receives messages because the disc slot turns on then blue...
Make sure you AVI(yellow,red,white)cables are pushed in all the way or you might have it on the wrong channel or you put the AVI cables in a differnt place than last time.
Feb 14, 2010 | Nintendo Wii Console
Playstation 2 slim won't turn on
try this:
- turn off PS2
- unplug PS2 and wait 1 minute
- plug in PS2 and turn it on
hope this helps :D
Jan 31, 2009 | Sony PlayStation 2 (PS2) Console
Wii will not load disk
YOu have to call Nintendo and send your consiole back for repair. Will take 9-15 business days for return. They will send you a call tag to send it Fed Ex back to them.
Jun 21, 2008 | Nintendo Wii Console
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
