Question about Sony KP-46WT510 46" Rear Projection HDTV
How do u change the coolant and clean the crt on KP-53v85/
3 Suggested Answers
SOURCE: Sony KP-53V85
I need the model number to give you exact answer..i suspect power supply it is probably a sony tv common problem regulators go bad and cold solder joints or samsung.
thanks DOCTOR VIDEO
Posted on Apr 25, 2008
  • 115 Answers
SOURCE: -anyone know where I can find a convergence repair
There is a convergence button on the front of the tv. If that doesn't work, the kit is only available to authorized servicers. Contact the manufacturer for an authorized servicer. esupport.sony.com
Posted on Jul 31, 2010
-anyone know where I can find a convergence repair kit for a sony kp-53v85
Jul 30, 2010 | Sony KP-46WT500 46" Rear Projection...
Double vision with redness
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 10, 2008 | Sony KP-53V85 53" Rear Projection...
KP-53V85 SONY PIC DOESNT LOOK AS CLEAR AS BEFORE.
Clean mirror and lamp lenses with a good glass cleaner (mild) but never put glass cleaner on your screen! dust can be the simple cause also focus it
Dec 08, 2008 | Sony KP-53V85 53" Rear Projection...
Broken screen on sony KP-53v85
HELLO. IT NOT THAT HARD TO REPLACE IT. THE HARD PART IS TO FIND ONE. AND THERE ARE ONLY TWO SCREEN ON THAT TV. AND I MIGHT HAVE WHAT U NEED .? GET BACK TO ME .!!! GOOD LUCK!!
Jun 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture, no sound
Is the led blinking when you press power? If so let me know the number of blinks its making.
May 18, 2008 | Sony KP-53V85 53" Rear Projection...
Sony KP-53V85
thanks DOCTOR VIDEO
Apr 25, 2008 | Sony KP-53V85 53" Rear Projection...
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Oct 18, 2007 | Sony KP-53V85 53" Rear Projection...
SONY REAR PROJECTION TELEVISION TV KP-53V85 53 IN
When the set turns off, does the red timer LED blink on the front of the set? If so, how many times does it blink? The number of blinks corresponds to the reason the set shut down.
Jul 05, 2007 | Sony KP-53V85 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
