Question about Digihome LCD TV
I don't how to set up the tv. It is working alright but last few weeks ago. I lost the manual.
I have a problem,I bought a apple i pod mp 3 player a few weeks ago at a flee market,worked fine up until last night I accidently went into lock screen and it went off and now I don't have a clue to...
There are 2 ways to try and unlock it if you don't know the passcode.
1) Connect your iPod to the computer set as the primary one in iTunes. Open the iTunes application, then disconnect your iPod from the computer, and it should no longer be locked.
Only use this next option as a last resort because it is a destructive process.
Everything on your iPod will be erased.
http://support.apple.com/kb/HT1339?viewlocale=en_US
Aug 25, 2011 | Apple iPod nano
My delonghi perfecta plus esam5450 tells me to descale when the last descale was only 3 weeks ago. It is 18 months old and I usually only need to descale every few months. However, the last 3 times i have...
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
Aug 16, 2011 | Microwave Ovens
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
At336 ns-np
Replace the following 4 capacitors on the power supply board They are CP624, CP639, CP641 and CP647 they are all 1000 uf 35V 105 degree radil capacitors. that should take care of the problem. If you need further help let me know.
Aug 04, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
I bought a Toshiba 42'' plasma TV exactly 1 year ago. The model, as per the hand book, is 42PD6600 A. About 8 weeks ago I began experiencing some problems to turn on the TV, i.e. the red light (stand...
maybe your ac cable has a lost contact thats why when you wiggle it it will turn on. just replace your power cable first before you are going to troubleshoot the other problem.
regards,
janex
Apr 22, 2008 | Televison & Video
Sylvvania 27" tv will not respond to universal remote....
it seems that there is problem with the remote receiver circuit of your tv since your remote is working alright with the other tv. inspect for possible cold solder on that circuit or failing component, but if you are not inlined with kind of job, better bring it to a qualified tv technician. good luck!
Feb 26, 2007 | Sylvania 6427TE 27" TV
Digihome LCD TV Logo
13 people viewed this question
Top Digihome Televison & Video Experts
john h
D. E. Hev
Are you a Digihome Televison and Video Expert? Answer questions, earn points and help others
