Turn mp3 player dvr usb - Audio Players & Recorders
Can I charge archos 604 batteries using dvr station and power outlet?
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Sep 09, 2010 | Archos 604 Digital Media Player
I have a dvr 595 how do i get music onto the mp3 player
It is not possible to transfer your music from the dvr 595 to the mp3 player.
Aug 12, 2008 | Vivitar Cameras
I need a manual for 4CH H.264 DVR
you might be able to get a manual download from www,ateck.com under "DVR Systems" and then "Support"
Apr 29, 2010 | Archos DVR Station MP3 Player
Recharging
unfortunitly i dun think it does but there are plently of adapter u can find at ur local elecltronic shops like best buy that should have maybe one thats simlar to ur needs
Dec 30, 2009 | GPX MW-3847 MP3 Player
My archos 5 120GB won't turn on, it is charged
have you tried charging it with the dvr station, ur usb could b the problem. it may indicate that it is charged but not...
Jun 28, 2009 | Archos Internet Media Tablet MP3 Player
My archos wont responed anymore when i plug into my pc
Make sure the usb cable is not damaged you can try to connect to pc by docking the device to DVR station or mini charging dock too there is 2 type of connections available for charging stations. By using another type of Usb cables. Mini usb 5 pins to usb.Same cable used for sony PSP also.
http://www.showmecables.com/viewItem.asp?idproduct=258
May 11, 2009 | Archos Internet Media Tablet MP3 Player
Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work.  Good Luck.
www.blogger.usarchos.com
Jan 31, 2009 | Archos DVR Station for Select Portable...
CRAIG mp3 player
this is what u do turn on ur computer then go to my documents after put in a cd go to windows media player click SYNC and if the screen of the mp3 player if it has two arrows pointing towards each other then its SYNCingt GOOD JOB!!!!! then un hook ur usb cord then turn on ur mp3 player go to music and it should be there! (:
Feb 29, 2008 | Audio Players & Recorders
Archos
does it have a battery? remove it
does it have a reset?
Dec 10, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
15 people viewed this question
 Grubhead
Grubhead
