Question about Norelco Arcitec Electric Shaver - Gray/Black
There is a flashing blue light on my razor
Flashing blue light shaped like a padlock on the bottom of my razor
Why has my Facebook page now showing what appears to be Arabic or similar printing? And how do I get it back to English?
Got to the padlock icon, John, on the right of the blue band at the top of the page. On the drop down click on the pale blue bit at the bottom, the left hand of the links, as you won't be able to read the arabic(!) On the next page that opens, look at the top left and you will see two small gear cog shapes, which is the general page. Click it.
Next will open your general account settings. Go to the second from the bottom and click on the word at the right hand side. This should open up the languages option for you to change it back to English. FYI English(Pirate) is a fun one to try. Good luck.
Jan 12, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck.
Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor.
http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display):
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
Jul 07, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
When then batteries are charged, i turn on the switch and the red and green light are on, then i pull the throttle and the yellow light flashes once. whats might be wrong?
The battery voltage is dropping under load, as indicated by the throttle light changing from green to yellow. Likely you batteries need replacing. most battery shops will test them for free to confirm they need replacing.
battery replacment guide and other trouble shooting information is avilable here
http://www.razorama.com/razor-installation-guides.html
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
I have a new ES-LA93 razor which I love but I have one question. After shaving I press the [SELECT] button to choose Clean/Dry/Charge. The process finishes and all seems fine but the CLEAN and DRY course...
If you clean the razor every day, the CLEAN and DRY lights flash repeatedly to show you that the cleaning has completed. You should be able to confirm that this is correct by NOT cleaning it one day. You should see that those lights don't flash then. I know this because I clean the razor twice a week rather than every day. On the days that I clean it, the lights flash. On the days that I don't clean it, the lights don't flash.
Nov 08, 2010 | Panasonic Health & Beauty
I can't pair Technocel T10 bluetooth with motorola Razor
With T10 off, hold the on/off button down. In 4 seconds the blue light will begin to flash but continue to hold down on the button until the red light also appears. You can now pair the T10 with the phone.
Nov 14, 2009 | Sony Ericsson TM506 Cell Phone
Dashboard Indicator Light
The vehicle is equipped with a security system. The light means it is armed.
Apr 10, 2009 | 2007 Mercury Mariner Premier 4WD
Has been working fine, now Razor phone cannot find it.
hoping this helps...
Explorer Series: 220,320, 330, 340, 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
The passkey is 0000
Sep 18, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 220
Try pairing it like this: Put the phone into pairing mode. Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue. The units should link up together.
Aug 15, 2008 | Plantronics - Bluetooth Headset Plus Base...
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Norelco Arcitec Electric Shaver - Gray/Black Logo
178 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
