Question about Sanyo SR-4310 Compact Refrigerator
Need a door gasket for compact fridge Sanyo SR360X
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: thermostat switch comes on but fridge does not cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
Why is the temperature erratic in my compact fridge?
Check the door gaskets. Close a dollar bill between the door and the gasket and pull out slowly, little or no resistance means the gasket is leaking at that location. You need to test it all the way around. Adjust as required, if its broken or distorted in some areas, replace it. If gasket is OK, check that the thermostat are is clean and clear so air flows around it easily. If that's OK, most likely you have a bad stat.
Mar 20, 2015 | Refrigerators
Hi! How do I find Sanyo compact ice storage replacement door? Thanks!
I'm assuming that your asking about a freezer door on a compact refrigerator. parts can be ordered on line @ sears direct, go to link below & enter model # or scroll down page & select refrigerators under, find parts by top product categories - scroll to refrigerator brands found - select Sanyo refrigerator parts - scroll down & select your model - select View all parts in this diagram, some parts will be available others you will have to call phone # provided. when looking @ your parts list there will be a exploded view on left ( to see it better click on view full size) http://www.searspartsdirect.com/partsdirect/brands-products/Sanyo-Parts/Refrigerator-Parts
Aug 18, 2014 | Sanyo SR-4910M Compact Refrigerator
The freezer door is missing
Look for a gasket for the freezer on the main door of the unit. This model may not have a separate freezer door. If there are hinge pins for a freezer door and this is new, contact whoever sold it to you and report the damage. Otherwise try Amazon, eBay or Samsung to buy the missing part.
Nov 03, 2012 | Sanyo SR-3660S Compact Refrigerator
Sanyo mini refrigerator continually runs
Check the door gasket to see if it seals correctly.
Aug 09, 2017 | Sanyo 4.4 Cu. Ft. Compact Refrigerator -...
I can't put the door back on. The top has fixed bolt (and a corresponding hole t the top of the door. But no idea how to attach the bottom. no fixed bolt on the fridge at the bottom, (but there is
There should be a piece usually triangular that bolts to the bottom of the fridge with a post sticking out of the end of it. The door rests on the pin then you attach the top mounting bracket and the door should be on
Sep 06, 2012 | Sanyo SR-3770S Compact Refrigerator
Door was left open. Frost in the back. Outside sides very warm. Doesn't sound like it's 'running.'
Move your food to another fridge. Shut your fridge off and manually defrost it. This used to be a farily common practice. Just leave the door(s) open, and let'er melt. You can have a fan blow in it (don't put the fan in the fridge). Thaw completely, and try again. It may have tripped on a thermal overload, so the compressor may have shut down. It may restart after it has cooled.
Regards, --W/D--
Aug 10, 2009 | Sanyo SR-4910M Compact Refrigerator
Need a replacement door gasket for compact fridge Sanyo SR1286-1
Here is a link to get exactly that Sanyo SR1286-1 door gasket. It says Panasonic on the page but it fits perfectly. O know, I bought one!
SR1286 1 Sanyo
Jun 03, 2009 | Sanyo SR-4310 Compact Refrigerator
Sanyo Mini Fridge
Same problem - When defrosting and moving away frost had a spray come from the left side of fridge. Can I repair - if a leak and how to add more freon?
May 03, 2008 | Sanyo SR-4910M Compact Refrigerator
Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Sanyo SR-4310 Compact Refrigerator Logo
83 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
