Question about Toshiba 57HM167 57" HDTV
Tv says lamp door open???? - Toshiba 57HM167 57" HDTV
My tosheba tv is saying lamp door open
Take your door off and inspect your switch. It is possible that you did not have the door seated properly.
Mar 21, 2013 | Televison & Video
Tv is say lamp door open
Remove the lamp door and inspect the door switch. You probobly didn't get the door seated correctly.
Mar 21, 2013 | Toshiba 65HM167 65" Projection Television
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
All of a sudden my tv will not go on lamp light is blinking
REPLACE THE LAMP, LAMP DOOR ON RIGHT SIDE OF TV OPEN TWO DOORS PULL BULB OUT GENTLY
REPLACE WITH NEW BULB
Dec 21, 2010 | Sony KDF-E42A10 42 in. LCD Television
I put a new lamp in tv wont come on lamp light keeps flishing
If the lamp light keeps flashing it usually means that either the lamp door has come loose /the existing lamp has burned out. The first thing to do would be to open the lamp doors(inner and outer) and make sure that they click into place. If problem persists then its time to replace the lamp.
Aug 26, 2010 | Hitachi UltraVision 60VF820 TV
JUST FOR WELCOMEJEE How easy is it to replace the lamp on a sony 50 wega ? I dont have the exact model but if you could give me a rough idea
Lamp replacement is very easy in Sony TV, unplug tv from wlll socket, let cool down for half an hour, check at left side of tv, you will see lamp door, open it to see another safety door, unlock it and slide it out, there you will see lamp, pull it out and put new lamp, and put safety door, lock it and then lamp cover.
Plug back tv in and turn it On.
Thanks.
Aug 21, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony LCD projection TV product code KDF-E42A12 which is almost 3 years old. It was working fine but suddenly made a 'clunk' noise and went blank. When switching it on the TV wont start but goes...
Three blinks means a lamp door error. There are two switches in your TV that put the TV into protect when either the lamp is not properly seated or the lamp door is loose.
First open the lamp door on the TV to check the lamp. A defective lamp sometimes could also cause the TV to generate this error code. If you see either a shattered or cloudy bulb then you will need to replace the lamp. The "Clunk" sound you hear was most likely the lamp shattering.
If the lamp is okay, you will need to check the switches for the lamp and lamp door. They are called the T1 and T2 boards. The T1 board is visible when you have the lamp door open. It is on one of the sides inside the TV on next to where the lamp door opens. You should see the switch which is a little board (about 1" by 2") with a very little (about 1/2" by 1/8" ) coming out on the side of the board. There is another board almost exactly like it called the T2 board near where the lamp goes into the TV. This could have also become loose. If you see the metal pieces are loose or missing, the boards need to be repaired. You could either replace the boards if the metal piece is missing or just repair the boards by setting the metal pieces in the correct potions where they make good contact with the switch when the lamp and lamp door in set properly.
Also you could just bypass the switches by making a solder bridge (solder across) the connection to the T1 and T2 boards that will trick the TV into thinking the Switches are closed and bypass this error.
Oct 12, 2009 | Sony KDF-E42A12U 42" LCD TV
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
I have a lg rt 52sz, lamp light flashed so i replaced the lamp, now when i turn the tv on the red light turns orange for 8 secnds then tv turns itself off, the lamp is still flashing. Signed unhappy...
make sure the lamp is in correctly and the door is also on good. there is a switch on the lamp door opening that wont let the set turn on if the door is not on.
Apr 24, 2009 | Televison & Video
Samsung HL-S5087W shuts off.
the number is 3409-000178
should cost less then $5
Dec 29, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 57HM167 57" HDTV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
