Question about Honeywell TrueDRY DR65 Whole House Dehumidifier
Honeywell TrueDry DR65 problems - Honeywell TrueDRY DR65 Whole House Dehumidifier
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Online manual.com
Home Hardware might be able to supply a manual although could be a Honeywell underneath.
Jun 09, 2014 | Danby Dehumidifiers
Vibration Noise Fix
Place the dehumidifier feet on foam or rubber vibration absorbing pads.
Touch all sides of the cabinet with the compressor running to see if your touch will dampen the noise. Once the noisy area is identified check that the fasteners are all in place and tight. Sometimes loostening and retightening a number of fasterners around the noisy area will cure this problem.
Apr 30, 2014 | Honeywell DR90A1000 TrueDRY Dehumidifier...
On the HUT200 model. Does not produce the mist
I have read elsewhere on this site that overheating of compressor may be low gas level, but does that mean there is a leak? I have had the machine about 3 years, used over 1000 hours.
Dec 15, 2013 | Kaz Inc Honeywell HUT200 Easy-Care Cool...
Model HDH 165 honeywell dehumidifier owners manual
I just got one from a friend of mine and we dont have a manual so i went to the honeywell site typed in the code HDH-165 and it comes back with nothing. kinda frusterating as i need my place to be cool and was told by gettong one of these it will take the mold smell and tthe heat out.
Jul 24, 2013 | Dehumidifiers
Need manual for honeywell dehumidifier model hdh 131
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 30, 2010 | Dehumidifiers
Honeywell TrueDRY DR65 Whole House Dehumidifier Logo
99 people viewed this question
Top Honeywell Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Honeywell Dehumidifier Expert? Answer questions, earn points and help others
