Question about Tools & Hardware - Others
Paslode im350 has indicator light flashing red/green
Been handed a redent paslode im350, the indicator light is flashing red/green and refuses to even start the fan. any ideas would be helpfull
Thanks Andy
  • 1,305 Answers
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Posted on Jun 23, 2009
Having experienced this problem firs hand you need to ensure that the motor .ie.the fan is still rotating easily.you can check this by simply spinning the fan.it sould turn easily and spin for a few seconds with no friction at all.If however the fan turns and stops quickly then i am afraid you face an expensive fix .
Posted on Oct 10, 2010
Paslode 350 tell no light
If you have no light at all in the handle and you're sure you have a charged battery, then I would look at the battery contacts - that tool has the contacts molded into a circuit board assembly so if it is not obvious I would take it to a repair center to be diagnosed.
May 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350/90ct green light goes red when applied to surface and wont fire
Unplug. Check that you don't have a nail jammed in the end of it.
Apr 03, 2012 | RTO Air Tools & Compressors
Paslode green light won't come on
if it flashes RED it usually means a bad or dead battery. If no light comes on then I would start looking at the contacts for corrosion and a loose connection on the circuit board/spark unit area. if no loose connection I would think the board is faulty
Feb 05, 2012 | Air Tools & Compressors
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Flashing green and red light by the trigger ,what does it mean
heatman101
0-
Oct 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Problem with battery connection
if you remove the battery and look into where the battery goes at the bottom you will see the two prongs that make contact with the battery pack gently pry away from the side not to far but just a bit if you can not insert battery when done you pried to, far just bend them back until all works properly
Nov 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My paslode IM350 fires about once every 20
by service im assuming you mean replacing the o-ring and seals/gaskets. If not do that. But if you have it may be more of an internal problem with the air valve leaking around the piston.
Aug 03, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Tools & Hardware - Others Logo
3,360 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
